i have understand the new() and create() but confuse about their uses.
when and where to use these two.
Does it create any problem if i use new () instead create().
thanks
surya
thanks
surya
It depends on if you want to use the Factory mechanism, both new() and create() will request memory and finish basic initialization for a specific object, however create() will gave you a object which probably pointed to a derived class.
In reply to caowangyang:
hi caowangyang,
that means in the derived class we don’t need to create the object if we use the create() in main class?
i am new to uvm . please don’t mind if it is an silly question
thanks
surya
In reply to snayak@aimstechnology.inc:
I could gave you an example here.
class a extends uvm_object;
`uvm_object_utils(a)\
endclass : a
class b extends class a;
`uvm_object_utils(b)\
endclass : b
a = new("a"); // Will just create a object pointed to a
a = a::type_id::create("a"); // Will create a object actually pointed to b if we use something like set_type_override_by_type(a.get_type(), b.get_type());
Hope it helps :)
