Nested associative arrays OR associative arrays of dynamic arrays
Hi Folks,
I would like to create an associative array where a string key points to another associative array or to a reference of one.
Similarly I would like to create an associative array where a string key points to a dynamic string array.
Does the language allow the above data types?
-ravi
*In reply to ravi.ck.kumar:*Yes. SystemVerilog supports arrays whose elements can be of any type. When dealing with dynamically sized array, you can think of it as arrays of arrays instead of multi-dimensional arrays. because an array element in each dimension can have a different number of elements.
You can declare arrays of arrays by using an intermediate typedef (preferred)
typedef int int_index_by_str_t[string];
int_index_by_str_t lookup[];
or
int lookup[][string];
Hi David,
Thanks for the pointers. Based on that I created a quick example…
module mytest();
typedef string AADD[*]; // create a hash type
AADD arrayOfAAs; // create an array of hashes
arrayOfAAs AAWC2[string]; // create a hash of ‘array-of-hashes’ <<— This Doesn’t.
AADD AAWC3[string]; // create a hash of hash. <<---- This Works!!
I get the following error. I would like to have a string to reference an array of hashes OR even
Error-[SE] Syntax error
memory of unknown type
“a.sv”, 6: token is ‘;’
*In reply to ravi.ck.kumar:*You need to use a type when declaring a variable.
typedef AADD arrayOfAAs[]; // create type of an array of hashes
arrayOfAAs AAWC2[string]; // create a hash of 'array-of-hashes'
or
AADD arrayOfAAs[]; // create an array of hashes
var type(arrayOfAAs) AAWC2[string]; // create a hash of 'array-of-hashes'
Also, I do not recommend ever using a wildcard associative array index type. Use an actual type. The wildcard index type is antiquated and cannot be used with a number of other systemverilog features.
The second typedef did the trick! Thanks much. Also true about using wildcards. Very little utility in the first place IMHO.
or
Is this mode of type declaration supported in system-verilog?
In reply to yourcheers:
Yes. See 6.23 Type operator of the 1800-2012 LRM. I forgot to add the var keyword in front of the type. I corrected my example.
hi Dave , can we create a typedef using some previous typedef like :
typedef enum bit [1:0] {OKAY, ERROR, RETRY, SPLIT} response
so i want to create an associative array using response as input and logic [31:0] as key
typedef resp_t address_driver_resp [logic [31:0]] ; // will this work ?
if yes , how do we register it in our transaction_item ?
In reply to DV@Engineer :
An associative array can have any element type, and any index type as long as equality is defined for the index type.
What do you mean by “register it”?
I am unclear by what you mean an array of hashes. Is this the same thing as using a key into an array of arrays?
People use many different terms for what SystemVerilog calls an associative array: map, dictionary, symbol table, or hash. However a hash usually refers to the lookup mechanism used to access an element, not necessarily an array. I tend to avoid it, but was just repeating terminology the previous post used.
Looks so counter intuitive.
feels more like an associative array of dynamic arrays.
But it is the other way round.
Why is this done?
When declaring the 2-dimensional fixed sized array int A[10][20], 10 ius the first dimension and 20 is the second dimension. Selecting A[0] gives you a 1-dimensional array of 20 elements.
Similarly selecting lookup[0] should give you an associative array.
