Q. When Sig_a goes low then for next 1 or 2 clock cycle we need to disable the assertion.
can we write it in disable iff condition. If yes, then how to write this condition inside disable iff ?
After the 1 or 2 cycles, use a task to trigger a disb signal for a short pulse.
Use the aceept_on to accept the property
// Q. When Sig_a goes low then for next 1 or 2 clock cycle we need to disable the assertion.
//can we write it in disable iff condition. If yes, then how to write this condition inside disable iff ?
timeunit 1ns; timeprecision 100ps;
`include "uvm_macros.svh" import uvm_pkg::*;
bit clk, a, b, c=1, reset_n=1, disb;
int p, f;
default clocking @(posedge clk);
endclocking
$timeformat(-9, 0, " ns", 10);
$display("%t", $realtime);
task automatic t_disb();
disb <=1;
@(posedge clk)
#1 disb <=0;
ap_disb: assert property(@ (posedge clk)
disable iff(reset_n==0) sync_accept_on(disb)
$rose(a) |-> ##[1:2] (b, t_disb ) ##5 c) p++; else f++ ;
bit v_a, v_b, v_err;
$dumpfile("dump.vcd"); $dumpvars;
// $dumpfile("Test_Adder_16.vcd");
// $dumpvars(1, Test_Adder_16);
repeat (200) begin
@(posedge clk);
if (!randomize(v_a, v_b, v_err) with {
v_a dist {1'b1 := 1, 1'b0 := 1};
v_b dist {1'b1 := 3, 1'b0 := 1};
}) `uvm_error("MYERR", "This is a randomize error");
a <= v_a;
b <= v_b;
$finish;
Ben@systemverilog.us
https://systemverilog.us/vf/Cohen_Links_to_papers_books.pdf
