Need help with these ( Lazy ) Constraints
I have come across following 3 Constraints , which I somehow feel is Lazy way of writing Constraints
 // CODE 1
rand bit [1:0] a , b ;
constraint IMPLI { a -> ( b == 3 ) ; } // EDIT :: LHS 'Operand' means what ??
[a] I am unsure what LHS of implication Constraint mean ?
Similarly if I modify it to ::
// CODE 2
rand bit signed [1:0] a ; //  a is inside {[-2:1]} !!
rand bit [1:0]  b ;
[b] In this case does the LHS mean the same as CODE 1 ? Or are they different
 // CODE 3
rand bit [7:0]  b ;
constraint ITERATN {
                       foreach(b[i])
                        if ( i ) // Index means what ??
                         b[i] == 1 ;
                       { b[i] == 0 ; }
 // CODE 4
rand bit signed [-2:1]  b ; // b has value inside {[-8:7]}
                       foreach(b[i])
                        if ( i )
                         b[i] == 1 ; // For which indexes ?
                       { b[i] == 0 ; }
[c]
Similarly in these 2 foreeach Consatrints ( Code 3 && 4 ) what does i indicate when if ( i ) is True ?
In reply to TC_2017:
LHS means Left Hand Side, the operand to the left of the operator. For
a -> ( b == 3
The operator is →
The LHS operand is a
The RHS operand is b==3
The implication operator can be re-written as simple Boolean equation:
!a || b==3
!a is the same as a==0;
These rules should answer all your questions.
Thanks Dave ,
The IMPLI constraint implies that whenever ( a != 0 ) , b is ALWAYS 3 .
Hence {a,b} combinations like {1,0} , {1,1} , {1,2} , {2,0} , {2,1} , {2,2} , {3,0} , {3,1} , {3,2}
NEVER OCCUR
 ( Out of the 16 possible Combinations )
When a is 0 , b can have all 4 values ( 0 - 3 )
