Hi
new here …
I need help with resolution function.
Only tried to implement the example given in the IEEE SV 2012 spec section 6.6.7
I wrote the following small code:
// user-defined data type T
typedef struct {
real field1 ;
bit field2 ;
} T ;
// user-defined resolution function Tsum
function automatic T Tsum (input T driver[]);
Tsum.field1 = 0.0 ;
foreach (driver[i])
**Tsum.field1 += driver[i].field1;
** endfunction
module drv (output T drv_out) ;
module top ();
nettype T wT ; // an unresolved nettype wT whose data type is T
nettype T wTsum with Tsum ; //
wT no_rf ;
// wire_with_rf with_rf ;
drv drv1 (
.drv_out(no_rf)
// drv drv2 (
// .drv_out(no_rf)
drv drv3 (
.drv_out(with_rf)
drv drv4 (
.drv_out(with_rf)
typedef struct {
real field1 ;
bit field2 ;
} T ;
Tsum.field1 = 0.0 ;
foreach (driver[i])
wire stam;
and I get the following ERROR:
which ncverilog
/nfs/iil/eda/tools/cadence/incisive/14.10.013/linux_2.6.16_x86-64/tools/bin/ncverilog
[176]icsl2618:/<6>Mixed_signals/SV/DFE_TB> ncverilog resolution_function_try.sv -sv -sysv +access+rwc +gui
ncverilog: 14.10-s013: (c) Copyright 1995-2014 Cadence Design Systems, Inc.
ncverilog: *N,SNPREC: The existing contents of the environment SPECMAN_PRE_COMMANDS will only be passed on to the simulation phase (conf gen -default_generator=IntelliGen;#ifndef CDN_UVC_USING_INTELLIGEN {define CDN_UVC_USING_INTELLIGEN;}).
file: resolution_function_try.sv
ncvlog: *E,SVRFINV (resolution_function_try.sv,23|28): function or class method does not conform to resolution function requirements.
ncvlog: *E,SVRFST (resolution_function_try.sv,11|17): static variable not allowed in resolution function.
ncvlog: *E,SVRFST (resolution_function_try.sv,11|37): static variable not allowed in resolution function.
module worklib.top:sv
errors: 3, warnings: 0
ncverilog: *E,VLGERR: An error occurred during parsing. Review the log file for errors with the code *E and fix those identified problems to proceed. Exiting with code (status 1).
Can someone help ?
