I have a DUT with an output tready and an input tenbl (which is connected to an AND gate with the tready signal and a valid signal coming from another module)
To verify this DUT, I use a UVM environment where I wrote a reference model that receives the inputs generated by my sequences and listen to the output of the DUT.
The issue I’m facing is when I call (for example in my driver) `uvm_info(), to display the value of tready, I observe a delay of 1 clk cycle (10ns in my simulation). Which is annoying because a need to detect a rising/falling edge of tready to be able to discard correctly the tenbl in my reference model.
How can I remove this delay ?
Here is pieces of my code to understand how my tb is written.
//The interface I use to connect the DUT
interface Interface(input bit clk);
logic rst;
logic[C_IMG_DATA_NBIT-1:0] img_data;
logic img_ready;
logic img_enbl;
endinterface: Interface
My module wrapper that instantiate a VHDL module,
the interface and generate my clock
module md_correlation_wrapper;
bit clk;
Interface dut_itf(.clk);
my_module u_my_module(
.clk(clk),
.rst(dut_itf.rst),
.img_data(dut_itf.img_data),
.img_ready(dut_itf.img_ready),
.img_enbl(dut_itf.img_enbl)
initial begin: clock_generator
clk = 0;
forever begin
#(C_CLK_PERIOD/2);
clk = ~clk;
end: clock_generator
endmodule: md_correlation_wrapper
My driver with a virtual interface that simply display the value of img_ready
class Driver extends uvm_driver#(Transaction);
`uvm_component_utils(Driver);
virtual Interface dut_itf;
super.new(name, parent);
endfunction: new
super.build_phase(phase);
if( !uvm_config_db #(virtual Interface)::get(this, "", "Interface", dut_itf) ) begin
`uvm_error("", "uvm_confid_db::get_failed")
endfunction: build_phase
forever begin
@(posedge dut_itf.clk);
if(dut_itf.img_ready == 0)begin
`uvm_info("", "img_ready == 0", UVM_MEDIUM);
endtask:run_phase
endclass: Driver
And here are a screenshot of what I see in the waves
and in the tcl console
You can see `uvm_info() is called 10ns too late
