static logic [DATA_WIDTH-1:0] test_vecs[5][dot_size*2] =
{’{dot_size{MAX_NEG_INPUT}}, ‘{dot_size{MAX_POS_INPUT}}},
{’{dot_size{MAX_POS_INPUT}}, ‘{dot_size{MAX_POS_INPUT}}},
{’{dot_size{MAX_POS_INPUT}}, ‘{dot_size{MAX_NEG_INPUT}}},
{’{dot_size{0}}, '{dot_size{0}}}}
I have been getting the following error for the above piece of code:
Number of elements in target expression does not match the number of
elements in source expression.
target Expression:
dotN_int_test_sequence.run.test_corner_inputs_outputs.unnamed$$_5.test_vecs
source Expression: ‘{’{{'{dot_size {MAX_NEG_INPUT}}, '{dot_size
{MAX_POS_INPUT}}}}, ‘{{’{dot_size {MAX_NEG_INPUT}}, '{dot_size
{MAX_POS_INPUT}}}}, ‘{{’{dot_size …
What do I do to fix this?
