Multiple Instances of a Covergroup
I’m trying to create multiple instances of a covergroup.But everytime it is throwing some error as invalid type.
//pseudo code
class cov_monitor extends uvm_component;
int a;
int b;
covergroup common_cg with function sample(axi_transaction txn,bit mode);
option.per_instance =1;
CP1 : coverpoint txn.a{
       bins ...
       bins...
endgoup
covergroup cov_cg with function sample(int mode);
CP2: : coverpoint   a{
     bins..
     bins..
endgroup
function new(string name= "cov_monitor",uvm_component parent);
common_cg = new();//Recognized Properly and Bins are hitting
cov_cg cg_rx = new();//Throws Error
cov_cg cg_tx=new();
function get_data();
//Sample Here
*Error:
Error-[SE] Syntax error
Token ‘cov_cg’ not recognized as a type. Please check
whether it is misspelled, not visible/valid in the current context, or not
properly imported/exported. This is occurring in a context where a variable
declaration, a statement, or a sequence expression is expected. Either the
declaration type is not known or this is incorrect syntax.
Can anyone help on this:)
In reply to ajithomas003:
SystemVerilog does not allow multiple instances of a class embedded covergroup. You must either declare the covergroup outside the class, or create a separate class with an embedded covergroup, and create multiple instance of that class.
Hi dave,
I have created covergroup inside the class. Created two instance for that class and samples the covergroup by using these two instance. But on seeing my coverage report I can able to see only one coverage. Can You please explain that exact method to use it
In reply to harimshr:
Are you using
If you already are using that option and only seeing one coverage item, you will have to check with your tool vendor’s documentation or support.
I have tried with that. In tool I could see instance hits same as score. I’m having doubt, that covergroup will be seen as two instance of it in tool or else only this instance will show it
endgroup spelling is not correct
