I have following Code ::
module dummy_dut(input value1, index1);
reg [7:0] data[100];
logic [7:0] value, index ;
always_latch begin
// Some Logic Here
data[index] <= value;
import uvm_pkg::* ;
`include "uvm_macros.svh"
dummy_dut dut1(value, index);
run_test("dummy_stimulus");
// On Uncommenting below I get Error ::
// Variable '/top/dut1/data[10]' "driven in a combinational block, may not be driven by any other process."
//initial begin
// data[10] = 5;
//end
class dummy_stimulus extends uvm_test;
`uvm_component_utils(dummy_stimulus)
function new (string name ="stimulus",uvm_component parent =null);
super.new(name,parent);
super.build_phase(phase);
top.dut1.data[5] = 10 ; // Works , but How ??
$display("DATA[%0d]=%0d",5,top.dut1.data[5]);
task main_phase(uvm_phase phase);
#10;
$display("inside main_phase");
My confusion is , since the build_phase() of the test is a seperate process , shouldn’t this be an error too ??
