A dist is a hard constraint that encompasses all the values with non-zero weighted in the bracketed set. As soon as you introduce the DIST2 constraint, you’re faced with a conflicting set of values. This is essentially the same as applying an inside constraint; the result is the intersection of the values in the two lists. If instead of adding the DIST2 constraint, you have the DIST1 and DIST3 values, the intersection of these values is only 15.
Seeking your comments on calculation of distribution weights in following case
1800-2023 says
If a value occurs in multiple items within a single distribution,
then the weights allocated to that value are additive.
For example:
x dist { [100:102]:=1, 101:= 1 }; // value 101 occurs twice
Weight associated to value of x = 101 would be additive i.e 1+1 i.e 2
Consider a hypothetical scenario where user has the following inline constraint for class Dist
Assuming only DIST1 exists in the class definition.
Dist d;
d = new();
// Different weights specified via inline constraint
if( !d.randomize() with { dst dist { 5:=2,[12:15]:=3 };} )
$error(..);
(A) What is the individual weight for dst equal to 5 / 12 / 13 / 14 / 15 ? Will weights still be additive ?
I believe LRM doesn’t mention a scenario where the weights are different via inline constraint or via separate constraint block.
Applying multiple distributions to the same random variable is asking for trouble. I believe that the weights are additive, regardless of whether the distribution is specified in multiple constraints blocks or in-line. Moreover, it’s important to remember that each value must have a non-zero weight in every distribution; otherwise, it’s considered a hard constraint that prevents that value from being part of the solution set.
Yes, I do agree that a user shouldn’t do it purposely
A final question from my side
dist constraint is essentially the same as applying an inside constraint with an addition of weights
Does this mean one can use an unpacked array variable in distribution set ?
rand bit [2:0] a;
bit [2:0] a_q[$]; // non-random variable
// Assuming queue 'a_q' is always non-empty during call to randomize
constraint dist_unpack { a dist { a_q }; } // default weight of 1 per element
// Above constraint is essentially an inside constraint
I am aware that an inside operator does allow an unpacked array variable in its range_list
LRM says
The distribution set is a comma set list of integral or real expressions and ranges
As per my understanding an unpacked array variable as a whole isn’t an integral expression,
an element of unpacked array would be an integral expression ( assuming it’s leaf element is integral type )
