MULTIPLE AGENTS FOR SINGLE INTERFACE
In reply to Aajay:
Hi all,
I found an axi master environment where it has 5 different agents for the five channels but the interface is only one.
Can we have multiple agents for single set of interface signals. is that accepted as per UVM standerds.
Please help me in knowing.
Thank you
If you have a multiple master testbench with the same types of masters then you need only 1 SV interface. But you are using multiple instances this interface each connected to an agent on the one hand side and connected to your DUT on the other side.
It is useless driving 1 interface instance from multiple agents.
