Hi, Thanks for helping out.
I have written a small code for 10 random 32 bit memory address generators.
There are two constraints → 1) Memory address has to be <1GB which works fine.
2) Select Memory address such that it doesn’t cross boundaries of 4kB.
My constraints work well if I do it for a single 32 bit memory. When I do it for 10 random 32 bit memory with foreach loop, the #2 constraint with modulo in it fails in it. It throws a Fatal Error: Unhandled exception (std): .
Please help me understand why.
//1GB memory with 4kB memory boundary. Cache lines are 0.5kB each.
class Memory_address;
rand bit [31:0] store_mem_addr [10]; //Store all the memory address
int cache_line = 500; // constant cache line size = 500 Bytes
// constraints for memory address
constraint c {
foreach (store_mem_addr[i])
//1. Memory address has to be within 0 to 1GB
store_mem_addr[i] inside {[0:1000000000]};
//2. Assume 4kB memory boundary. Prevent mem_addr such that memory crosses boundary. This line of code below throws fatal error.
store_mem_addr[i]%4000 + cache_line < 4000;
function void print();
for (int j=0; j<10; j++)
$display("Memory address %d): %d", j, store_mem_addr[j]);
endclass: Memory_address
module memory;
Memory_address addr1;
addr1 = new;
//Generate 10 cache lines with constraints
assert(addr1.randomize());
addr1.print();
