what should be a method for scale down factor of timer? there are so many timers and I need to scale it down with some factor.
In reply to tech_savvy:
Not sure what you are referring to, or even what domain (design, or testbench). Perhaps: Timer/Counter Module - A Controller Independent Guide - EmbedJournal
I need to write uvm code for scale down factor of timer.
You should give us some more details for your task you have to implement. In which way you have to scale down etc …
there are so many timers in my protocol, so i need to scale down its timeout value by scaledown factor. for it i need to write a method. So how to write that method?
Then you have to divide the timeout value by the scaledown factor. There is nothing magic.
So do i need to set value of scaledown factor or just i should declare field (int scaledownfactor) in configuration class and user will set scaledown value accordingly.
I do not know how your environment looks like. There are several approaches posible. You can use simply a parameter or using a configuration object. This depends also what your objective is. Do you want to scale down with ranom values or not.
yes i want to scale down with random values.
Then you can create a configuration object with the scaling factor and possibly some additional data mebers you might use, creat, randomize this object and pass it to the config_db. Then you can retrieve it in any place you need this object.
I have written this code but not getting correct value
class scaling;
  int pclk;
  int scaledown;
  real polling_cnt;
  function pri(int pclk, scaledown);
    realtime polling = 0.6us;
    polling_cnt = (polling * pclk) / scaledown;
module priyanka();
  scaling s=new();
  //int pclk,scaledown;
    s.pclk = 500000000;
    s.scaledown = 1000;
    s.pri(s.pclk,s.scaledown);
    $display("%d ",s.polling_cnt);
Your code is not really clean. See my code below working:
class scaling;
  bit pclk;
  function realtime pri(int scaledown);
    $display("scaledown = %d ", scaledown);
    pri = polling / scaledown;
    $display("pri = %f ", pri);
    return pri;
module priyanka();
  int scaledown = 1;;
  realtime polling_cnt;
  scaling s=new();
    scaledown = 200;
    repeat (3) begin
      polling_cnt = s.pri(scaledown);
      $display("%f ",polling_cnt);
      scaledown = 10 * scaledown;
I have changed something in your code.
class scaling;
int pclk;
function realtime pri(int scaledown,pclk);
pri = 0.00000006*pclk / scaledown;
return pri;
module priyanka();
int scaledown = 1;
int pclk = 1;
int polling_cnt;
scaling s=new();
scaledown = 1000;
pclk = 500000000;
repeat (3) begin
polling_cnt = s.pri(scaledown,pclk);
pclk = 0.5 *pclk;
-Now the question is there are 3 different values of pclk: 500000000, 250000000, 125000000. So for this, i wrote pclk = 0.5*pclk. But driver will use one value at a time, so how to code this?
Again, I assume pclk is your clock signal. This signal has values 1’b1 and 1’b0.
What is in your eyes
pclk = 0.5 *pclk;
What you want to do is something like this in your clock generator:
always #scaledown pclk = ~pclk;
actually realtime polling is timer, i need to change this timer value into counter. For this i have to multiply pclk and polling timer value (polling *pclk) and then i need to scaledown. So my query is should i take all three values of pclk in my configuration class or driver will take care of it?
Again, what is pclk?
Pclk is A clock frequency… There are 3pclk: 500Mhz, 250Mhz and 125Mhz
I’m not sure if yiu are right. I believe pclk is a clock signal which can have 3 different frequencies. This is different what you are saying.
Ya pclk is A clock signal with 3differenet frequency
Then you have to define pclk as data type bit (2 states) or logic (4 states).
The click generaror generating your clock signal has to be configurable for the 3 clock frequencies.
That’s it.
