Merits of Overriding Sequence Items
I am going to strongly disagree with the statement “Therefore, from a practical point of view, sequence_items are unlikely to be overridden” (Cookbook Section UVM/Sequences/Overrides).
I am going to provide two examples of how type overrides with sequence items has been very useful for me.
While I do want to test the entire state-space of possible stimulus, I often want to narrow my stimulus for certain tests. By heavily constraining my stimulus I am actually able to hit certain scenarios. An example could only running maximum or minimum size packets for an extended duration. If I need to run a large number of these packets in a row to create a scenario, then this is unlikely to happen without additional constraints. I could do this by writing a new sequence that constructs these derived sequence items that have additional constraints, but that seems like it would be slightly more code and more files than extending a sequence_item and using a type_id_override().
My other example is that I often find bugs and sometimes I am not responsible for fixing them. However, I still want to find other bugs while that bug is being fixed. Therefore I create a test that exhibits the bug and document it. However, I then introduce new constraints in a derived class to mask the bug and have all my other tests use type overrides to enforce these constraints. This allows me to temporarily mask known issues while I hunt for more bugs or work on adding more coverage.
In reply to James.Kolar:
I agree with your disagreement. They were probably only thinking about overrides that added new class member variables or methods. Overriding class constraints is a very common factory override for any class with random variables.
Hey Dave,
I also agree with your point but I didn’t understand you line,
“They were probably only thinking about overrides that added new class member variables or methods.”
Can you elaborate more about it.
That section of the cookbook explains how the sequence-to-driver communication is specifically designed for a particular sequence_item. It wouldn’t make sense to add a new variable to a sequence_item unless the driver is also extended to read that variable. However, there are numerous cases where extending a sequence item is beneficial. Many people create base sequence items and extend them for use with a driver, while also extending them differently for use with a monitor by adding responses. Of course, the cases raised by the original poster, which involve extending the sequence item to add constraints, are a common practice. Therefore, the cookbook statement is clearly misleading.
