Section 16.12.22 of the LRM says
Any sequence that is used as a property shall be nondegenerate and shall not admit any empty match
I am intrigued by the starting of the sentence “Any sequence that is used as a property” i.e what does it mean ?
Consider the following scenarios:
// Case 1: sequence used as consequent
sequence s1;
<some_seq_expression1>
endsequence
ap_case1:assert property( a |=> s1 );
// Case 2: sequence directly asserted
sequence s2;
<some_seq_expression2>
endsequence
ap_case2:assert property( s2 ); // Same as ap_case2:assert property( <some_seq_expression2> );
// Case 3: sequence_expr used as consequent
ap_case3:assert property( <some_seq_expr3> |=> <some_seq_expr4> );
[Q1] Since a property_expr can’t be part of sequence body, would s1 be interpreted as sequence_expr ( rather than a property_expr ) ?
I am aware that a sequence_expr is by default a property_expr and consequent is a property_expr
[Q2] Are all 3 cases ap_case1,ap_case2 and ap_cse3 examples of “sequence used as a property” ?
