Here is the code I am referring to. This code is from SV LRM:
module test;
class BasePacket;
int A = 1;
int B = 2;
function void printA;
$display("BasePacket::A is %d", A);
endfunction : printA
virtual function void printB;
$display("BasePacket::B is %d", B);
endfunction : printB
endclass : BasePacket
class My_Packet extends BasePacket;
int A= 3;
int B= 4;
int C= 5;
$display("My_Packet::A is %d", A);
endfunction: printA
$display("My_Packet::B is %d", B);
endclass : My_Packet
BasePacket P1 = new;
My_Packet P2 = new;
P1.printA; // displays 'BasePacket::A is 1'
P1.printB; // displays 'BasePacket::B is 2'
$display("P1 =%0h",P1);
$display("P2 =%0h",P2);
P1 = P2; // P1 has a handle to a My_packet object
P1.printB; // displays 'My_Packet::B is 4' latest derived method
P2.printA; // displays 'My_Packet::A is 3'
P2.printB; // displays 'My_Packet::B is 4'
One issue I see with this code is that the derived class is re-defining class members which is illegal in SV AFAIK. Can anyone please clarify this?
There is no section in lrm which says re-defining is illegal in class inheritance. Whenever a child class extends base class it gets all it’s contents which includes variables, methods, constraints; now in child class one can re-declare any of these and that would get effective for child class.
It may not be a good programming practice, but there is nothing illegal about re-defining class properties in an extended class. The thing that you have to remember is that re-defining is really overriding or hiding the definition in the base class. The members still exist in the base class.
Thanks for the reply Dave,
Please consider the following portion of the code:
why would P1.printB display 4 instead of 2?
How come the base class handle is able to access derived class variable values?
If B in derived class is considered as a member that overrides B in the base class, then when printing B using a virtual function should surely print ‘My_Packet::B is ’ but should not be able to access the derived class variable B. If I try to print variable C in the virtual function in the derived class that would be a run time error. I am assuming the same rule applies to variable B in the derived class. Please let me know what I am missing.
Prashant,
The polymorphism applies to virtual methods. In this example P1 is pointing to a derived object and hence accesses “modified/derived virtual method named printB” - that method has access to all values in the DERIVED class, including C. The variable hiding is more of inheritance phenomenon.
In reply to Srini @ CVCblr.com:
Thanks for the reply Srini. I am Prasad by the way.
I tested the code to print variable C and it works. Using virtual functions one can access new members of derived classes. But one cannot directly access like P1.C ! I fail to understand why?
What exactly happens when we do upcasting using the following statement?
P1=P2?
I thought it would be a simple copy of everything in P1 from P2. It does not seem to be the case.
I did review the video you have pointed out. If it is a simple copy of the handle then why will P1.C be illegal? If you print the value of P1 and P2 they are the same, but they definitely do not behave the same.
I am looking for explanation in terms of how memory allocation of the object happens. When base handle is pointing to an extended object, why can’t we access the variables of the extended object? what happens during upcasting and downcasting other than pointers being copied?
