Hi all — quick question about reducing repetitive RAL code.
I have two register objects, iplr0 and iplr1. Their fields are declared like this:
iplr0contains:
rand uvm_reg_field irq0_prio;
rand uvm_reg_field irq1_prio;
rand uvm_reg_field irq7_prio;
iplr1contains:
rand uvm_reg_field irq8_prio;
rand uvm_reg_field irq9_prio;
rand uvm_reg_field irq15_prio;
My goal is to randomize each IRQ priority so every field value is <= 3. Right now I do this manually:
void'(ral.iplr0.randomize() with {
irq0_prio.value <= 3;
irq1_prio.value <= 3;
irq7_prio.value <= 3;
ral.iplr0.write(status, ral.iplr0.get());
ral.iplr0.update(status);
void'(ral.iplr1.randomize() with {
irq8_prio.value <= 3;
irq9_prio.value <= 3;
irq15_prio.value <= 3;
ral.iplr1.write(status, ral.iplr1.get());
ral.iplr1.update(status);
This is verbose and error-prone. Can I do this with a single loop (or macro/helper) that iterates register index iplr0..iplr1 and fields irq0_prio..irq15_prio, sets each field to a value <= 3, and then writes/updates the registers? Any compact examples (using get_field_by_name, get_fields, macros, or small helper tasks) would be much appreciated.
Thanks!
