I would like to know how loop exit conditions in Systemverilog are evaluated.
For example, if I have a for loop
for (idx = 0; idx < queue.size();idx++)
Now within this loop, if I delete entries in the queue, would the compiler check size for every iteration or just once.
My initial hunch was that this is a static evaluation by the compiler and it would loop queue.size() times, as evaluated initially.
But I wrote a small piece of code and looks like compiler evaluates queue.size() for every iteration.
Below is the code:
module x;
integer Q[$] = { 1,2, 3, 5, 6, 7, 8, 9, 10};
for (int idx = 0; idx <= Q.size(); idx++) begin
$display("idx %d val %d size %d", idx, Q[idx], Q.size());
Q.delete(idx);
Below is the output:
idx 0 val 1 size 9
idx 1 val 3 size 8
idx 2 val 6 size 7
idx 3 val 8 size 6
idx 4 val 10 size 5
Can anyone provide more insight including any LRM section reference?
Correct. I’ve noticed that when Verilog / SystemVerilog borrows concepts from C it assumes the reader is already familiar with how C works, so that the LRM isn’t as explicit as the C standard. For comparison, the C standard specifies for-loops as:
The statement
for ( clause-1 ; expression-2 ; expression-3 )
behaves as follows: The expression expression-2 is the controlling expression that is evaluated before each execution of the loop body. The expression expression-3 is evaluated as a void expression after each execution of the loop body. If clause-1 is a declaration, the scope of any identifiers it declares is the remainder of the declaration and the entire loop, including the other two expressions; it is reached in the order of execution before the first evaluation of the controlling expression. If clause-1 is an expression, it is evaluated as a void expression before the first evaluation of the controlling expression. Both clause-1 and expression-3 can be omitted. An omitted expression-2 is replaced by a nonzero constant.
