Hi,all
I am trying to write to dut register using uvm ral front door access ,when i am done with initial build of ral model , i am calling lock_model of uvm _reg_block to lock register model , it is not coming out of lock_model function of uvm_reg_block,below i have attached part of code here.
but it is not coming out of lock_model function(it is not returning from lock_model function).
Can anyone please tell me what is the issue here?
Thanks in advance.
`ifndef ping_pong_register;
`define ping_pong_register;
//---------------register field -------------------//
class ping_pong_register extends uvm_reg;
rand uvm_reg_field ping_pong_reg_field;
`uvm_object_utils(ping_pong_register)
function new(string name = "ping_pong_register");
super.new(name, 32'd192, build_coverage(UVM_NO_COVERAGE));
endfunction: new
// Build all register field objects
`uvm_info(get_full_name(),"INSIDE ping_pong_register starting of BUILD function",UVM_LOW)
this.ping_pong_reg_field = uvm_reg_field::type_id::create("ping_pong_reg_field",, get_full_name());
// configure(parent, size, lsb_pos, access, volatile, reset, has_reset, is_rand, individually_accessible);
this.ping_pong_reg_field.configure(this, 32'd192, 0, "WO", 1, 1'h0, 0, 0, 0);
`endif
//-------------------register block----------------//
`ifndef ral_sys_eon;
`define ral_sys_eon;
class ral_sys_eon extends uvm_reg_block;
rand ping_pong_register pi_po_reg; // RO
`uvm_object_utils(ral_sys_eon)
function new(string name = "ral_sys_eon");
super.new(name, build_coverage(UVM_NO_COVERAGE));
`uvm_info(get_full_name(),"INSIDE ral_sys_eon starting of BUILD function",UVM_LOW)
this.default_map = create_map("", 0, 1, UVM_LITTLE_ENDIAN, 0);
//3rd orgument in create_map indicates bus width of 1 byte
this.pi_po_reg = ping_pong_register::type_id::create("pi_po_reg",,get_full_name());
this.pi_po_reg.configure(this, null, "");
this.pi_po_reg.build();
//this.default_map.add_reg(this.ctrl, `UVM_REG_ADDR_WIDTH'h0, "RW", 0);
this.default_map.add_reg(this.pi_po_reg,'h3f, "RO", 0);
lock_model();
`uvm_info(get_full_name(),"INSIDE ral_sys_eon ending of BUILD function",UVM_LOW)
`endif
//------------------------------top environment in which i have instatiated uvm_ral environment----------------------------//
class eon_env extends uvm_env;
`uvm_component_utils(eon_env)
spi_agent s_agent_h;
reg_env reg_env_h;
eon_scoreboard eon_sb_h;
spi_coverage spi_covg_h;
function new(string name = "eon_env",uvm_component parent);
super.new(name,parent);
//***********build phase*****************//
super.build_phase(phase);
`uvm_info(get_full_name(),"INSIDE EON ENV starting of BUILD PHASE",UVM_LOW)
// creating the handles
s_agent_h = spi_agent :: type_id::create("s_agent_h",this);
eon_sb_h = eon_scoreboard::type_id::create("eon_sb_h",this);
spi_covg_h=spi_coverage::type_id::create("spi_covg_h",this);
reg_env_h=reg_env::type_id::create("reg_env_h",this);
`uvm_info(get_full_name(),"INSIDE EON ENV ending of BUILD PHASE",UVM_LOW)
super.connect_phase(phase);
`uvm_info(get_full_name(),"INSIDE EON ENV starting of CONNECT PHASE",UVM_LOW)
// connecting the monitor and scoreboard
s_agent_h.spi_mon.spi_ap_h.connect(eon_sb_h.spi_fifo.analysis_export);
s_agent_h.spi_mon.spi_ap_h.connect(spi_covg_h.analysis_export);
s_agent_h.spi_mon.spi_ap_h.connect (reg_env_h.m_spi2reg_predictor.bus_in);
reg_env_h.m_ral_model.default_map.set_sequencer(s_agent_h.spi_seqr, reg_env_h.m_reg2spi);
`uvm_info(get_full_name(),"INSIDE EON ENV ending of connect PHASE",UVM_LOW)
//---------------RAL adapter ------------------//
class reg2spi_adapter extends uvm_reg_adapter;
`uvm_object_utils (reg2spi_adapter)
spi_txn pkt;
function new (string name = "reg2spi_adapter");
super.new (name);
virtual function uvm_sequence_item reg2bus (const ref uvm_reg_bus_op rw);
pkt = spi_txn::type_id::create ("pkt");
`uvm_info(get_type_name(),"reg to bus call inside adapter starting ",UVM_MEDIUM)
// pkt.set_sequencer (this.tmp_seqr);
pkt.cmd_type = (rw.kind == UVM_WRITE) ? spi_txn::spi_txn_cmd_type_e'(1): spi_txn::spi_txn_cmd_type_e'(0);
pkt.addr = rw.addr;
// pkt.data=new[4];
pkt.data[0] = rw.data[7:0];
pkt.data[1] = rw.data[15:8];
pkt.data[2] = rw.data[23:16];
pkt.data[3] = rw.data[31:24];
`uvm_info(get_type_name(),$psprintf("packet is %s",pkt.sprint()),UVM_MEDIUM)
`uvm_info(get_type_name(),"reg to bus call inside adapter ending ",UVM_MEDIUM)
`uvm_info ("adapter", $sformatf ("reg2bus addr=0x%0h data=0x%0h kind=%s", pkt.addr, pkt.data, rw.kind.name), UVM_DEBUG)
return pkt;
virtual function void bus2reg (uvm_sequence_item bus_item, ref uvm_reg_bus_op rw);
spi_txn pkt;
`uvm_info(get_type_name()," bus2reg call inside adapter starting ",UVM_MEDIUM)
`uvm_info(get_type_name(),"bus_to_reg_call inside adapter ",UVM_MEDIUM)
if (! $cast (pkt, bus_item)) begin
`uvm_fatal ("reg2spi_adapter", "Failed to cast bus_item to pkt")
rw.kind = pkt.cmd_type== spi_txn::spi_txn_cmd_type_e'(1)? UVM_WRITE : UVM_READ;
rw.addr = pkt.addr;
rw.data[7:0] = pkt.data[0];
rw.data[15:8] = pkt.data[1];
rw.data[23:16] = pkt.data[2];
rw.data[31:24] = pkt.data[3];
`uvm_info(get_type_name()," bus2reg call inside adapter ending ",UVM_MEDIUM)
`uvm_info ("adapter", $sformatf("bus2reg : addr=0x%0h data=0x%0h kind=%s status=%s", rw.addr, rw.data, rw.kind.name(), rw.status.name()), UVM_DEBUG)
//-----------------test class -------------------//
`ifndef eon_ral_ping_pong_wr_test;
`define eon_ral_ping_pong_wr_test;
class eon_ral_ping_pong_wr_test extends base_test;
//----------FACTORY REGISTRATION----------------
`uvm_component_utils(eon_ral_ping_pong_wr_test)
ral_sys_eon ral_sys_eon_h;
//-------------CONSTRUCTOR-----------------------
function new(string name="eon_ral_ping_pong_wr_test", uvm_component parent);
`uvm_info(get_full_name(),"BUILD PHASE - BASE TEST",UVM_LOW)
this.ral_sys_eon_h=env_h.reg_env_h.m_ral_model;
virtual function void end_of_elaboration_phase(uvm_phase phase);
uvm_phase run_phase = uvm_run_phase::get();
run_phase.phase_done.set_drain_time(this, 300ns);
virtual task main_phase(uvm_phase phase);
// ral_sys_traffic m_ral_model;
uvm_status_e status;
int rdata;
phase.raise_objection(this);
`uvm_info(get_type_name(),"before making a call to m_ral_model.cfg.timer[1].write inside test ",UVM_MEDIUM)
ral_sys_eon_h.pi_po_reg.write (status, 32'h3f);
`uvm_info(get_type_name(), $sformatf("desired=0x%0h mirrored=0x%0h", ral_sys_eon_h.pi_po_reg.get(), ral_sys_eon_h.pi_po_reg.get_mirrored_value()), UVM_MEDIUM)
`uvm_info(get_type_name(),"after making a call to m_ral_model.cfg.timer[1].write inside test ",UVM_MEDIUM)
//ral_sys_eon_h.pi_po_reg.read (status, rdata);
phase.drop_objection(this);
