Hi Guys,
I am facing issues with my assertions where I am making use of $time or $realtime.
Below is the example property:
property clk_freq_check(logic [1:0] phy_rate, integer clock_period);
real time_stamp1, time_stamp2, time_stamp;
integer time_period;
@(posedge env_if.clk_in) disable iff (env_if.mac_phy_rate != phy_rate)
$rose(env_if.pll_lock) ##20 (time_stamp1 = $time) ##1 (time_stamp2 = $time) ##1 (time_stamp = (time_stamp2 - time_stamp1)) ##1 (time_period = $rtoi(time_stamp)) ##1 (time_period == clock_period);
clk_gen1_assert: assert property(clk_freq_check(2'b00, 'd8000));
Here is the error message:
Error-[EWSENATE] Expression with side effects
…, “(time_stamp1 = $time)”
Expressions with side effects not allowed in temporal expressions.
Expression: “(time_stamp1 = $time)”
And as a part of further debug, I tried to simplified the code as shown below:
property clk_freq_check(logic [1:0] phy_rate, time clock_period);
time current_time;
$rose(env_if.pll_lock) ##20 (current_time = $realtime) ##1 (clock_period = $realtime - current_time);
…, “(current_time = $realtime)”
Expression: “(current_time = $realtime)”
In both the examples $time/$realtime was not allowed.
Could someone help with the effective solution here. Here env_if is the interface handle. I have not shown the complete module details here. Kindly assume all other things are taken care, this is mainly regarding usage of timestamps.
Thanks in advance
user49
July 20, 2018, 12:33am
2
In reply to prashanth.billava :
One of the possible alternatives to write a sequence is
(sequence_expr {, sequence_match_item})[sequence_abbrev]
// I would rewrite your code as:
realtime time_stamp1, time_stamp2, time_stamp;
$rose(env_if.pll_lock) |->
##20 (1, time_stamp1 = $realtime)
##1 (1, time_stamp2 = $realtime)
##0 (1, time_stamp = (time_stamp2 - time_stamp1))
##0 (1, time_period = $rtoi(time_stamp)) //Why the ##1 in your model?
##0 (time_period == clock_period);
// More clear
##1 (1, time_stamp2 = $realtime),
time_stamp = (time_stamp2 - time_stamp1),
realtime current_time;
##20 (1, current_time = $realtime) ##1 (clock_period = $realtime - current_time);
VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy
http://systemverilog.us/vf/SolvingComplexUsersAssertions.pdf
“Using SVA for scoreboarding and TB designs”
http://systemverilog.us/papers/sva4scoreboarding.pdf
“Assertions Instead of FSMs/logic for Scoreboarding and Verification”
October 2013 | Volume 9, Issue 3 | Verification Academy
SVA in a UVM Class-based Environment
