Can you help me with running the following sequences?
I have one sequence that returns pcie_ltp when calling seq.start(null), and returns tlp. I want to use this in another sequence.
I tried as follows, but the test is getting terminated abruptly.
task body();
pcie_tlp.start(null);
`uvm_create_on(seq_item, seqr)
seq_item.data = pcie_tlp.data;
`uvm_Send(seq_item)
It’s not completely clear what issue you are describing, so perhaps describing what you expect to happen would help.
It seems that pcie_tlp is a virtual sequence, and you use ‘data’ from that virtual_sequence as part of another sequence_item. If this is the case, then you shouldn’t be using fork to run these two in parallel. I would think that pcie_tlp needs to complete first, and then seq_item can be sent.
One recommendation is to not use the uvm_create_* and uvm_send* macros as they can cause some unknown behaviors. Instead, use the create()/start_item() and finish_item() calls.
Yes, this is the exact scenario. Will wait help me achieve the same result, or is there another way to wait?
#2us; //Expecting this to finish within this time.
