I am seeing an issue with fork join when using within a for loop. I have pasted along with the edaplayground links for both examples
In the first example the sequences are not starting in parallel at the same time though i used a for loop inside a fork join
In the 2nd example i simplified a bare example just to see the flow of fork join vs for loop and that seems to start all the threads at time 0 where as in the 1st example similar concept isn’t starting all my sequences at time0.
Any issues with my code?
class my_sequencer;
int id;
endclass : my_sequencer
class my_sequence;
task start (my_sequencer seqr);
int delay = $urandom_range(1,10);
$display("time: %0d, starting sequence on sequencer with id:%d", $time, seqr.id);
#(delay * 1us);
$display("time: %0d, finishing sequence on sequencer with id:%d", $time, seqr.id);
endtask : start
int temp;
my_sequencer seqr;
my_sequencer seqr_q[$];
my_sequence seq[$];
my_sequence s;
static int num_of_seqr = $urandom_range(3,5);
for (int i = 0; i < num_of_seqr; i++) begin
seqr = new;
seqr.id = i;
seqr_q.push_back(seqr);
$display("queue size is %0d",seqr_q.size);
temp = seqr_q.size;
$display("temp = %0d",temp);
//s = my_sequence::type_id::create("s");
s = new();
for(int i=0;i<temp;i++)
seq.push_back(s);
//seq = new[seqr_q.size()];
//foreach(seqr_q[i]) seq[i] = my_sequence::type_id::create("seq[i]");
foreach(seqr_q[i]) seq[i] = new();
fork begin
for(int i=0;i<seqr_q.size();i++)begin
seq[i].start(seqr_q[i]);end
join
wait fork;
$display("time%0d, end reached", $time);
queue size is 3
temp = 3
time: 0, starting sequence on sequencer with id: 0
time: 10000, finishing sequence on sequencer with id: 0
time: 10000, starting sequence on sequencer with id: 1
time: 19000, finishing sequence on sequencer with id: 1
time: 19000, starting sequence on sequencer with id: 2
time: 29000, finishing sequence on sequencer with id: 2
time29000, end reached
V C S S i m u l a t i o n R e p o r t
// Code your testbench here
// or browse Examples
module test;
$display("-------------------------------");
for(int j=0;j<4;j++) begin
$display("Thread %d, %d",j,$time);
//#1;
$display("Thread new %d",$time);
join
Compiler version Q-2020.03-SP1-1; Runtime version Q-2020.03-SP1-1; Mar 26 17:21 2021
Thread 0, 0
Thread 1, 0
Thread 2, 0
Thread 3, 0
Thread new 0
