I am facing an issue in getting correct value of elements of dynamic array
Below is my code :
typedef enum bit [3:0] {
YUV,......RAW8,...} data_type_en;
rand data_type_en data_type_1 [];
rand int raw_data_size ;
constraint data_type_1_cn
data_type_1.size == 10
foreach(data_type_1[i])
data_type_1[i] == RAW8;
constraint raw_data_size_cn
raw_data_size == calc_size(); //Calling function
constraint sib_order_cn
solve data_type_1 before raw_data_size;
function int unsigned calc_size()
//I added followoing display here to find data_type_1.size
// which is correctly displayed as 10
$display("data_type_1.size = %0d", data_type_1.size);
//I added display to find data_type for each i
// The value it showed is 0th value i.e. YUV;
//while I have assigned RAW8 in constraint
endfunction : calc_size
In post randomize method, I get the correct element value for data_type_1 as RAW8. So does this mean that as soon as data_type_1.size is set, the constraint for solve before gets applied and so raw_data_size constraint is applied; though the elements of the array are not assigned the constrained value?
Here the raw_data_size depends on the element value of dynamic array
