Hi!
I have this scenario where I need to instantiate the same agent class 3 times in my environment where each agent differs it parameters.
In this case the parameter will be the depth of the register map.
eg. [10:0] reg [DEPTH]
While doing so there is a driver that would drive signals to the interface.
The issue here is that I only have one instance of the VIF in my agent and driver where I set it in the test top. And I need to drive the interface that would also vary its size.
Is it possible to use different parameters of interfaces on the same class agent instantiated multiple times?
