as described in the subtitle. I want to use a function to return the larger value.
There is no built-in function to compare two numbers and return the largest. There is a max method for arrays that returns the largest element in the array.
You should use the let statement instead of a function to handle values of any type.
let max(a,b) = (a > b) ? a : b;
Thanks Dave!
