In our code base, when creating an instance of a sequence inside an environment, we pass two parameters to create() which are string name and parent. But I don’t understand the reasoning behind it and also UVM doesn’t complain about it.
Here is an example code:
class test_magic_seq_c extends uvm_sequence#(magic_word);
class magic_env_c extends uvm_env;
test_magic_seq_c test_magic_seq;
test_magic_seq = test_magic_seq_c::type_id::create("test_magic_seq", this);
endclass: magic_env
I would appreciate if someone can provide me a reason how this is valid as sequence is uvm_object.
Could you please elaborate on this as generally ‘parent’ is passed for uvm_component and not for uvm_object. Also, as sequence class gets extended from uvm_object, why do we pass parent when creating a sequence. (constructor of uvm_object/uvm_sequence class also has a single parameter of ‘name’)
function new ( string name = "uvm_sequence" )
Is it that if we don’t pass parent parameter, it’s not possible to instance override?
Isn’t this partially true ?
As we discussed in thread the 3rd argument ‘contxt’ to create function also enables instance override for both uvm_object and uvm_components irrespective of whether an actual was passed to 2nd argument ‘parent’ of type uvm_component.
From what I am able to recollect from all examples that I have tried in the past, if all 3 arguments are passed to create , the ‘contxt’ argument takes precedence over ‘parent’ and the instance override should be set using the ‘contxt’ argument.
I found a blog which has examples of instance override using ‘contxt’ argument and without passing an actual to parent argument.
