Is it possible to let two instances to generate same sequence of random numbers?
Hi All,
I have a class that generates 10 random numbers. And in the test program, I create two instances c1 and c2. I wonder if it is possible to let c1 and c2 generate the same sequence of number? That’s to say, if c1 generates 7,8,3,2,5,1,4,0,9,6, I wonder if it is possible to let c2 also generates 7,8,3,2,5,1,4,0,9,6?
I tried to use srandom() to set the initial seed, but it seems to have no effect on the result.
class c_rng;
  int i;
  task gen_print();
    repeat(10)begin
    	i=$urandom;
    	$display("i=%0d",i);
module test;
  c_rng c1,c2;
    c1=new();
    c2=new();
    c1.srandom(1);
    c2.srandom(1);
    $display("c1 generates");
    c1.gen_print();
    $display("c2 generates");
    c2.gen_print();
Thanks in advance for your help!
Hao
In reply to peterjin:
$urandom uses the process RNG, not the class RNG. Change $urandom to randomize and your code works.
class c_rng;
  rand int i;
  function void gen_print();
    repeat(10)begin
      void'(randomize());
module test;
  c_rng c1,c2;
    c1=new();
    c2=new();
    c2.set_randstate(c1.get_randstate());
    c1.gen_print();
    c2.gen_print();
I prefer to use the RNG from c1 to set the RNG of c1. You don’t want to get involved managing seeds and master seeds.
Thanks so much for your help!
