Hi
I have a an uvm component. i know i can get the full name using get_full_name. I am not able to determine how to find if the component is present under a certain hierarchy?
Is reg ex matching the only option?
Hi
In reply to justrajdeep:
It depends on from which context you want to ask this question. If you are in the child component, you could repeatedly call get_parent and then see if get_parent().get_name() matches what you are looking for.
However, the UVM tries to avoid dependencies that rely on hierarchical references. If lower level component want to make a decision based on which hierarchy it sits in, a better option might be to have the higher level component make a setting in the config_db for the lower level component to retrieve.
I would have preferred doing a config_db call. But that pertains to extending the already existing agents.
My requirement is to take a decision on my sequence based on which sequencer it is running on.
You didn’t mention anything about a sequence in your original question. You said you had a component; that is a completely different context.
You can use get_sequencer() from the running sequence and then use the config_db from the sequencer handle.
You may also want to look at Config/ConfiguringSequences | Verification Academy
Thanks Dave this helps. I was doing the same in a more roundabout way. doing a get_sequencer() call and then trying to determine the hierarchy of the sequencer component.
