Hello !
Is it possible to use struct inside the clocking/modport for defining the directions for signals defined inside a struct. I was trying to define a simple struct as shown below.
typedef struct packed {
logic rst;
logic addr;
} dummy_struct_if;
And tried instantiating inside an interface to use the same inside the clocking block
interface dummy_if;
dummy_struct_if dummy_struct_if_s;
clocking dummy_cb@(posedge clk);
input dummy_struct_if_s.rst;
input dummy_struct_if_s.addr;
endclocking: dummy_cb
endinterface: dummy_if
But I faced this below compile error.
Error-[SE] Syntax error
"../../dummy_if.sv", 30: token is '.'
input dummy_struct_if_s.ram_rst;
I haven’t seen any examples in the SV LRM as well portraying using struct inside the clocking block. Is it possible to define a struct inside a clocking block/modport or not ?
In reply to desperadorocks:
Clocking block variables need simple names. You need to use this syntax.
interface dummy_if;
input rst = dummy_struct_if_s.rst;
input addr = dummy_struct_if_s.addr;
Now you can refer to dummy_cb.rst and dummy_cb.addr.
Thanks Dave for your inputs. But won’t this be like duplicating the signals ?
a. By default we need to use/define rst and addr in the interface.
b. Along with that we need to instantiate the dummy_struct_if, and do the connection you described above.
So that we can use dummy_struct_if within the active and passive components to drive/monitor right? Any specific reason why the LRM/rules doesn’t allow declaring straight-away the structs which contains the signal and define the sampling and directions ? Please clarify.
If you want all the fields of the struct in the same direction, just declare dummy_struct_if_s as a clocking block input; there’s no need to specify the individual fields.
And you are in fact declaring “duplicate “ variables in the scope of the clocking block which is why the variable names need to be simple identifiers.
