In our project, we have used several Xilinx IPs that work together with our custom modules. The Xilinx IPs contain more than 100 registers. When using UVM simulation, we need to configure these registers in the IPs through the AXI Lite bus.
In this situation, we might need to create a register model similar to the code below. However, is there a way to directly read and write to these registers by manipulating their addresses and thereby avoid creating this reg model?
`ifndef REG_MODEL__SV
`define REG_MODEL__SV
class reg_invert extends uvm_reg;
rand uvm_reg_field reg_data;
reg_data = uvm_reg_field::type_id::create("reg_data");
// parameter: parent, size, lsb_pos, access, volatile, reset value, has_reset, is_rand, individually accessible
reg_data.configure(this, 1, 0, "RW", 1, 0, 1, 1, 0);
`uvm_object_utils(reg_invert)
function new(input string name="reg_invert");
//parameter: name, size, has_coverage
super.new(name, 16, UVM_NO_COVERAGE);
class reg_model extends uvm_reg_block;
rand reg_invert invert;
default_map = create_map("default_map", 0, 2, UVM_BIG_ENDIAN, 0);
invert = reg_invert::type_id::create("invert", , get_full_name());
invert.configure(this, null, "");
invert.build();
default_map.add_reg(invert, 'h9, "RW");
`uvm_object_utils(reg_model)
function new(input string name="reg_model");
super.new(name, UVM_NO_COVERAGE);
`endif
