Is it necessary for comparison of data in scoreboard we should use check_phase?
Actually I have some problem in comparing data in run_phase of scoreboard. When I am comparing in run phase of scoreboard the data’s are not matching although when I am printing both data they are coming as same. But when I moved my comparing logic to check_phase then their is no mismatch. All data matched . What is the reason behind these mismatch in scoreboard’s run phase ?
In reply to Subhra Bera:
Impossible to answer without knowing the timing of the data you are trying to compare, but most likely a race condition.
The purpose of the check_phase is to do comparisons after the test has finished executing, so it might be more appropriate to do the check there.
Did you try the case equality? There might be x or z in your data. Or the format is wrong.
There can be more reasons. Do you apply the compare data as a transaction?
Yes I tried case equality but they did not work. Actually I am writing scoreboard logic for SPI. I have taken a queue of apb(master) sequence item in scoreboard. And another queue of SPI sequence item. I have taken an associative array in scoreboard for mimicking the DUT model.
I am poping out data from apb_queue and based on address(apb sequence item) I am storing the the data in the associative array. Then when spi_queue is getting its first data. Then I am comparing based on the character length.
SPI DUT has Tx0,Tx1,Tx2,Tx3,Rx0,Rx1,Rx2,Rx3,ctrl,divider,ss register. All are 32bit in size. There address are 00,04,08,0c,10,14,18 in hexadecimal(Tx and Rx registers address are same).ctrl[6:0] is the length of the character to be send and received.
when I am taking logic[31:0] char_len variable in scoreboard. In this variable I am storing associative_array[ctrl_addr]. And based on char_len[6:0](character length) I am comparing.
I have taken logic[127:0]Total_tx variable. And storing like Total_tx={Tx3,Tx2,Tx1,Tx0}; and then based on char_len[6:0] I am comparing. like
 for(int i=0;i<char_len;i++) begin
                           if(Total_tx[i]==MOSI[i]) (Mosi is the spi slave sequence item
                          k++;                            data of 128 bit length logic type
                       else                                                         variable)
                        break;
and then if k==char_lenth then data matches.
But Tx_Total=10203040102030401020304010203040;
MOSI= XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX40(30 X, 2 DIGIT)
CHAR_LEN =8 BUT data is not matching.
You should show how you are extracting your transactions. This help might hrlp to resolve the issue.
//Macros to create the uvm_analysis_imp ports (just an export + write function)
  `uvm_analysis_imp_decl(_apb_port)
  `uvm_analysis_imp_decl(_spi_port)
class spi_scoreboard extends uvm_scoreboard;
  `uvm_component_utils(spi_scoreboard)
string m_name;
virtual irq_if irq_if_1;
///golden reference model
logic [31:0] dut_model_w[*];//for mimicing the  writing into the dut reg
logic [31:0] dut_model_r[*];//for mimicing the reading from the dut reg
logic[31:0] ctrl_reg_value;// to know the ctrl register value
logic[127:0] Tx_reg_value,Rx_reg_value;
logic[6:0] char_len;
// for checking purpose
int k,l;
apb_seq_item apb_item,apb_item_2;
spi_seq_item spi_item,spi_item_2;
uvm_analysis_imp_apb_port#(apb_seq_item,spi_scoreboard)apb_imp;
uvm_analysis_imp_spi_port#(spi_seq_item,spi_scoreboard)spi_imp;
//queue to store data which will come from apb and spi side
apb_seq_item apb_dataQ[$];
spi_seq_item spi_dataQ[$];
logic[127:0] MOSIDATA,MISODATA;
extern function new(string name="spi_scoreboard",uvm_component parent =null);
extern function void build_phase(uvm_phase phase);
extern task run_phase( uvm_phase phase );
extern function void write_apb_port(apb_seq_item apb_item_1);
extern function void write_spi_port(spi_seq_item spi_item_1);
extern function void extract_phase( uvm_phase phase );
extern function void check_phase(uvm_phase phase);
extern function void report_phase( uvm_phase phase );
endclass:spi_scoreboard
 function spi_scoreboard::new (string name="spi_scoreboard", uvm_component parent=null);
    super.new(name, parent);
     m_name=name;
  endfunction : new
function void spi_scoreboard:: build_phase(uvm_phase phase);
 super.build_phase(phase);
 if(!uvm_config_db#(virtual irq_if)::get(this,"","irq_if",irq_if_1))
  `uvm_fatal("NO IRQ IF",{"virtual interface of IRQ must be set for:",get_full_name(),".irq_if"});
 spi_imp=new("spi_imp",this);
 apb_imp=new("apb_imp",this);
endfunction:build_phase
function void spi_scoreboard:: write_apb_port(apb_seq_item apb_item_1);
       $cast(apb_item,apb_item_1.clone());
      `uvm_info(get_type_name(),$sformatf("writing in the apb write method \n %s",apb_item.sprint()), UVM_LOW)
      apb_dataQ.push_back(apb_item);
function void spi_scoreboard:: write_spi_port(spi_seq_item spi_item_1);
    $cast(spi_item,spi_item_1.clone());
    `uvm_info(get_type_name(),$sformatf("writing in spi write method \n %s",spi_item.sprint()),UVM_LOW)
    spi_dataQ.push_back(spi_item);
task spi_scoreboard:: run_phase( uvm_phase phase );
      forever begin
         foreach(apb_dataQ[i]) begin
           apb_item_2=apb_dataQ.pop_front();
          `uvm_info(m_name,$sformatf("Scoreboard \n %s",apb_item_2.sprint()),UVM_LOW)
              if(apb_item_2.we) begin
                    dut_model_w[apb_item_2.addr]=apb_item_2.data;
                   // $display("dut_model_w=%p",dut_model_w);
             else begin
               dut_model_r[apb_item_2.addr]=apb_item_2.data;
                //$display("dut_model_r=%p",dut_model_r);
           Tx_reg_value={dut_model_w[32'h0c],dut_model_w[32'h08],dut_model_w[32'h04],dut_model_w[32'h00]};
           Rx_reg_value={dut_model_r[32'h0c],dut_model_r[32'h08],dut_model_r[32'h04],dut_model_r[32'h00]};
           ctrl_reg_value = dut_model_w[32'h10];
           char_len=ctrl_reg_value[6:0];
                  wait(spi_dataQ.size())begin
                      spi_item_2= spi_dataQ.pop_front();
                      MOSIDATA=spi_item_2.MOSIDATA;
                      MISODATA=spi_item_2.MISODATA;
                      $display($time,"MOSIDATA[127:0]::%b\n MISODATA[127:0]::%b",MOSIDATA[127:0],MISODATA[127:0]);
function void spi_scoreboard::  extract_phase(uvm_phase phase);
super.extract_phase(phase);
             else begin
function void spi_scoreboard::  check_phase(uvm_phase phase);
super.check_phase(phase);
//compare logic
      for(int j=0;j<char_len;j++) begin
          if(MOSIDATA[j]===Tx_reg_value[j])
             k++;
            break;
      for(int m=0;m<char_len;m++) begin
          if(MISODATA[m]===Rx_reg_value[m])
             l++;
            break;
       apb_dataQ.delete();
       spi_dataQ.delete();
function void spi_scoreboard:: report_phase( uvm_phase phase );
//report
 super.report_phase(phase);
    `uvm_info(get_type_name(), "============================", UVM_NONE)
    `uvm_info(get_type_name(), "Scoreboard Results", UVM_NONE)
     if(char_len==k&&char_len==l)begin
                   `uvm_info(get_type_name(), "TEST PASSED", UVM_NONE)
                   `uvm_info(m_name,$sformatf("CONSIDERED CHARACTER LENGTH::%d",char_len),UVM_LOW)
                   `uvm_info(m_name,$sformatf("DATA SENT FROM APB MASTER IS MATCHED WITH DATA IN MOSI LINE::\n\n\n       MOSI DATA SENT FROM APB MASTER::%b\n MOSI DATA COLLECTED FROM SPI MONITOR::%b\n\n",Tx_reg_value[127:0],  MOSIDATA[127:0] ),UVM_LOW)
                   `uvm_info(m_name,$sformatf("DATA SENT FROM SPI SLAVE IS MATCHED WITH DATA IN MISO LINE::\n\n\n        MISO DATA SENT FROM SPI SLAVE::%b\n MISO DATA COLLECTED FROM APB MONITOR::%b\n\n",MISODATA[127:0],Rx_reg_value[127:0]),UVM_LOW)
        else begin
                 `uvm_info(get_type_name(), "TEST FAILED", UVM_NONE)
Here actually I have written 12 sequence item through apb_driver within which 8 of which are writing operation and 4 are reading operation. All of the sequence item are coming to queue of type apb_seq_item. But the first 8(write seq item) are stored in the queue first and the scoreboard run_phase is taking out those 8 item from the queue and after that it completes run_phase. But the apb_seq_item which come some time after to the queue, scoreboard is not considering them in run_phase. If I use extract phase then only it able to extract the remaining sequence item . Otherwise it is not happening . Why this problem is coming?
