is $fell(sig_a) true when sig_a from x to 0?
$fell returns true if the lsb of the expression changes from 1/X/Z to 0
The same can be verified using
logic sig_a;
always@(posedge clk) begin
  if( $fell(sig_a) )
      $display("T:%0t $fell(sig_a) is true",$time);
  else
      $display("$T:%0t fell(sig_a) is false",$time);
// Add your stimulus as part of initial block
This would be true even when sig_a is sampled 0 on consecutive clocks
Using sv-property-fell the solution would be
!isunknown( $past(sig_a[0]) ) && $fell(sig_a)
