is $fell(sig_a) true when sig_a from x to 0?
In IEEE1800-2017, the $fell() is defined as
— $fell returns true (1’b1) if the LSB of the expression changed to 0. Otherwise, it returns false
(1’b0).
Does it mean $fell returns true if the LSB of the expression changed from 1/x/z to 0? or only 1→0?
if x/z→0 are true, is !$isunknown($past(sig_a))&& !sig_a legal for 1→0 only?
$fell returns true if the lsb of the expression changes from 1/X/Z to 0
The same can be verified using
logic sig_a;
always@(posedge clk) begin
  if( $fell(sig_a) )
      $display("T:%0t $fell(sig_a) is true",$time);
      $display("$T:%0t fell(sig_a) is false",$time);
// Add your stimulus as part of initial block
This would be true even when sig_a is sampled 0 on consecutive clocks
Using sv-property-fell the solution would be
!isunknown( $past(sig_a[0]) ) && $fell(sig_a)
$fell returns true if LSB of signal is changed to 0 from 1,x,z
Hi Dave, is this really true?. In a former SV version $fell returned 1’b1 only in case of changes from 1’b1 to 1’b0 (in contrast to negedge)?
Yes, it has been this way since before becoming an IEEE standard.
