I have a few questions regarding parameterized test ( which would act as uvm_test_top )
`include "uvm_macros.svh"
`include "uvm_pkg.sv"
import uvm_pkg::*;
class my_test # ( type T = int , T par = 10 ) extends uvm_test ;
`ifdef M1 `uvm_component_param_utils ( my_test#(T,par) ) `endif
`ifdef M2
`uvm_component_registry ( my_test#(T,par) , $sformatf("my_test_%0s_%0d",$typename(T),par) ) // [A]
const static string type_name = {"my_test#(",$sformatf("my_test_%0s_%0d",$typename(T),par),")" } ;
// NOTE :: Overriding Property [ 2 type_name exists (a) type_name (b) super.type_name() ] !!
function string get_type_name() // NOTE :: Error to declare it as static , Virtual ( in uvm_test ) by default !!
return type_name ;
`endif
function void build_phase ( uvm_phase phase ) ;
`uvm_info(get_name(),$sformatf(" type_name is ",type_name),UVM_NONE) // [B]
module TOP ;
// Make Specialized Class
my_test #(int,10) top1 ;
my_test #(int,20) top2 ;
run_test("my_test_int_20");
[1] Using +define+M1 :: It’s unable to create a component since its not registered with the factory . Is there a way around ?
[2] Using +define+M2 I see discrepancy across simulators ( Not the EDA ones , but the licensed ones at work ) .
Some are able to create instance of my_test#(int,20) while others flash “Class specialization parameter must be constant” at line [A] above .
[3] Using `uvm_component_param_utils , user needs to create own type_name variable and get_type_name function .
Is there a helper macro for this ?
[4] If I want to run specialized test via command line +UVM_TESTNAME= , what should ARG be given as ?
[5] Can I use text substitution macro "T" in [A] above instead of $typename(T) ?
In reply to MICRO_91:
- You can manually create the top level instance.
module TOP ;
uvm_test top;
top = my_test #(int,10)::type_id::create("my_test_int_10",null);
run_test("");
If you want command line control, you would have to look at your own switch instead of using +UVM_TESTNAME
module TOP ;
uvm_test top;
string testname;
if (!$value$plusargs("MY_TESTNAME=%s",testname)) `uvm_fatal("", "No test specified")
case(testname)
"int_10": top = my_test #(int,10)::type_id::create("my_test_int_10",null);
"int_20": top = my_test #(int,20)::type_id::create("my_test_int_20",null);
default: `uvm_fatal("", "Test not found")
endcase
run_test("");
- Yes, tools are inconstant in support of $sformat as a parameterization.
- There are no existing helper macros. You could copy the functionality of
`uvm_component_utils into another macro that takes two arguments; the first being the same argument to uvm_component_param_utils, and the second one being a unique string parameter. That’s a small amount of code, but I don’t have the time to explain the internals of that macro. Another approach that has the same effect is extending each class specialization into an unparameterized class.
class my_test_int_10 extends my_test#(int,10);
`uvm_component_utils(my_test_int_10)
super.new(name,parent);
class my_test_int_20 extends my_test#(int,20);
`uvm_component_utils(my_test_int_20)
That would be easy to turn into a macro
`define my_test_spec(T,V) \
class my_test_``T``_V extends my_test#(T,V); \
`uvm_component_utils(my_test_``T``_V) \
function new(string name, uvm_component parent); \
super.new(name,parent); \
endfunction \
`my_test_spec(int,10)
`my_test_spec(int,20)
- The answer to 3) lets you use +UVM_TESTNAME
- No. The replaced string would be the same for each class specialization.
