Inout signal error in uvm interface
Hi all;
I written in interface
logic sda_out; //inout signal driving for bi-directional signal from UVC
wire sda; //inout signal driving for bi-directional signal from DUT
assign sda=sda_out;
I want verify master vip so i need assign some values to sda. once i assigned to sda questa simulator given error
** Error: (vsim-8220) tb/top.sv(33): This or another usage of ‘vif.sda’ inconsistent with ‘net’ object.
How handle inout signal?
Is
wire sda declared in interface definition alongwith
logic sda_out??
If yes then you should not use assign statement to assign a continuous changing values.
If sda and sda_out to be part of same interface, then declare sda also of logic type and use assign it in your top module.
example
interface master_vip_if();
logic sda_out;
logic sda;
endinterface
assign master_vip_if.sda = master_vip_if.sda_out;
Dipali
In reply to dipali:
Hi dipali…
I understand your solution thanks…
In my case their is no DUT or slave VIP, so i try to generating slave signal(data,ack) in top module, and slave signal(sda)to communicate with master.
So in that case you can directly connect sda in slave_if to sda_out in master_if in top module.
In reply to dipali:
Thanks for your quick response.
I done but sda signal is alone driving whatever its value,i thinking driving sda task/function with check certain conditions.
I think your requirement is not so clear from the description you have given.
Please elaborate in detail about the problem you are facing.
In reply to dipali:
I am new to UVM world, working on I2C vip. In I2C signal sda is bidirectional signal, for writing data on sda from my master driver for a particular address, i dont have slave vip or dut so i try generating red data in my master top module, for that i used vif.sda=0; but simulator given an error Error: (vsim-8220) tb/top.sv(33): This or another usage of ‘vif.sda’ inconsistent with ‘net’ object.
Please guide me how to do it?
It is better to develop slave class as well and connect these signals. Responding to an interface signals for a particular functionality from top module is not a good approach.
PS: The is not related to UVM!
In reply to dipali:
Thanks…i will do slave part also …
Modelsim/Questasim provides a ‘verror’ command to gain more insight for a specific error message. For this case, verror provides the following information:
Message # 8220:
The specified object name was used in a place where the type of that
object is not allowed. For example, using the hierarchical name of a
net as the LHS of a procedural assignment would produce this message.
NOTE 1: If more than one use of the object name exists, consider all
occurrences in resolving the error.
NOTE 2: If this error follows error number 8776 then please fix the
cause of 8776 before fixing this error.
The error is from your statement:
vif.sda=0;
Since sda is declared as a wire in your interface, you cannot assign a value with this procedural assignment. However, you can use:
vif.sda_out=0;
This will work since sda_out is of type ‘logic’.
You can use here system verilog “alias” construct to connect bi-directional port of i2c master & slave.
Example
my_interface intf(clk);
// master i2c port
wire scl_m ;
wire sda_m ;
pullup p1(sda_m);
pullup p2(scl_m);
assign intf.i2c_m_scl_i = scl_m;
assign intf.i2c_m_sda_i = sda_m;
assign scl_m = intf.i2c_m_scl_en_o ? intf.i2c_m_scl_o : 1’bz;
assign sda_m = intf.i2c_m_sda_en_o ? intf.i2c_m_sda_o : 1’bz;
// slave i2c port
wire scl_s ;
wire sda_s ;
pullup p3(sda_s);
pullup p4(scl_s);
assign intf.SCL_In = scl_s;
assign intf.SDA_In = sda_s;
assign scl_s = intf.scl_en ? intf.SCL_Out : 1’bz ;
assign sda_s = intf.sda_en ? intf.SDA_Out : 1’bz ;
// connect master & slave bi-directional port.
alias scl_m = scl_s;
alias sda_m = sda_s;
