In the TLM, Why we need a export,because I can connect a port directly to the IMP,without a export.
In reply to liuxiaole:
You make a direct connection when the port and imp are at the same level in the testbench hierarchy. But as you add layers to the hierarchy, you need to create exports providing access to the IMP. In TLM-speak, the port is the caller/initiator and the export/imp is the callee/responder.
Hello, Dave
Actually, a direct connection of tlm port - tlm impl. between components in different hierarchy level is working without any tlm exports.
Is it a kind of policy?
my test code is below.
A.subA.subsubA.a_p.connect(B.subB.a_impl); // direct connection
import uvm_pkg::*;
`include "uvm_macros.svh"
class my_data extends uvm_object;
`uvm_object_utils(my_data)
int id;
function new(string name="my_data");
super.new(name);
virtual function void do_print(uvm_printer printer);
super.do_print(printer);
printer.print_field_int("id", id, $bits(id), UVM_DEC);
class subsubcomponentA extends uvm_component;
`uvm_component_utils(subsubcomponentA)
uvm_analysis_port#(my_data) a_p;
my_data data;
int cnt = 3;
super.new(name, parent);
a_p = new("a_p", this);
`uvm_info(get_type_name(), "run_phase", UVM_LOW)
while(cnt>0) begin
`uvm_info(get_type_name(), $sformatf("before a_p.write(%d)", cnt), UVM_LOW)
data = my_data::type_id::create("data");
data.id = cnt--;
a_p.write( data );
class subcomponentA extends uvm_component;
`uvm_component_utils(subcomponentA)
subsubcomponentA subsubA;
subsubA = subsubcomponentA::type_id::create("subsubA", this);
class componentA extends uvm_component;
`uvm_component_utils(componentA)
subcomponentA subA;
subA = subcomponentA::type_id::create("subA", this);
class subcomponentB extends uvm_component;
`uvm_component_utils(subcomponentB)
uvm_analysis_imp#(my_data, subcomponentB) a_impl;
a_impl = new("a_impl", this);
function void write(my_data data);
`uvm_info(get_type_name(), "write", UVM_LOW)
data.print();
class componentB extends uvm_component;
`uvm_component_utils(componentB)
subcomponentB subB;
subB = subcomponentB::type_id::create("subB", this);
`uvm_component_utils(my_test)
componentA A;
componentB B;
A = componentA::type_id::create("A", this);
B = componentB::type_id::create("B", this);
virtual function void connect_phase(uvm_phase phase);
module tb;
run_test();
