//overwritten parameters
class birds;
int size_inch = 20;
int lifetime = 10;
string colour = “brown”;
function void get_properties;
$display (size_inch, lifetime, colour);
class parrot extends birds;
string colour = “green”;
function void get_properties();
module a;
birds b;
parrot p;
b = new();
p = b;
$cast (p,b);
p.get_properties;
b.get_properties;
In reply to Sujatha.T:
Hi Sujatha,
Please, use code tag it will help to understand your code easy way.
module a;
birds b;
parrot p,p1;
b = new();
p = b; // it is illegal to assign base handle to derived class. it will give error
$cast (p,b);
p = new();
b = p;
$cast (p1,b); // Down cast is only possible if base class handle pointing to derived class handle.
p.get_properties;
b.get_properties;
p1.get_properties;
Please check below paper. Downcast is well explained in this.
http://www.sunburst-design.com/papers/CummingsSNUG2018SV_Virtuals.pdf
Thanks!
