Hi ,
I have the Following snippets ::
SNIPPET 1
rand byte x, y;
byte v, w;
constraint c1 { x < v && y > w ; ) // Logical AND
SNIPPET 2
rand byte x, y;
byte v, w;
constraint c1 { x < v ; y > w ; ) // Separated by semicolon
[Q1] Is there any difference between the 2 Snippets ?
I use it in the following Code
class CA;
rand logic x , y; // Using 4 State Type with Default 'X'
byte v, w; // 2 State type Defaults to 0
constraint c1 { x < v ; y > w ; }
CA c1;
c1 = new();
c1.x = 0;
c1.y = 0;
// Made 0 explicitly so that Constraints Don't Fail
if ( c1.randomize(v,w) )
$display("Failure");
$display("%p",c1); // I get OUTPUT :: '{x:0, y:0, v:0, w:0} , Why so ??
repeat(5)
$display("%p",c1);
$display("Failure"); // Get Failure Always
In the First Display I get that randomization fails , but not sure why ? .
w Being 2 State Signed can take values Less than 0 . Even v can take values up to +127
Regards,
AGIS
