Hi ,
Would appreciate if this problem is resolved.
I am trying to read data from an Image file (.raw - 800600 resolution);
I could only read the data from the file partially , afterwards the file pointer does not seem to move further.
Say , if the file has 200 items, it reads only 150 items and doesn’t seem to move further. Is it something wrong with the EOF?
i am not sure.
My code is as follows →
`define EOF 32'hFFFF_FFFF
class input_video_IF;
integer input_file, read_char,output_file;
function new ();
input_file = $fopen("test_800.raw", "r");
if(input_file)
$display("File OPENED");
$display("File error");
output_file = $fopen("output_800.raw", "w");
endfunction:new
task image_file_read();
while (!$feof(input_file))
read_char = $fgetc(input_file);
$display("%h",read_char);
$fwrite(output_file,read_char);
$fclose(input_file);
endtask : image_file_read
program Image_read_test;
int input_file;
input_video_IF In_IF = new();
initial
In_IF.image_file_read();
endprogram
Request your earliest reply…
Thanks!
Maybe try
function void image_file_read();
while ((read_char = $fgetc(input_file)) != -1)
endfunction : image_file_read
As $fgetc doesn’t give the input data in correct format i used $fscanf.
The file actually contains 1440000 bytes (8006008). The positive thing is , now it reads all the data
and goes beyond it. So now i have to check the counter value. Why it doesn’t find the EOF?
I have read the same image using VHDL which uses EOF file checking. So we can conclude the file is not corrupt with EOF.
i changed the code
count = 0;
while (data_byte != -1)
file_status = $fscanf(input_file,“%h”,data_byte);
count++;
$display(“%d %h”,count,data_byte);
if(count == 1440000)
$finish;
//$fwrite(output_file,read_char);
In reply to rockgarden333:
The functionality of $fgetc and $fscanf are very different. Apparently, you are not reading a raw binary image, you are reading an ASCII hex encoded file.
You need to check the file_status, which will return 0 when reaching the EOF.
Yes Dave, you are right.
Sorry for confusing you. $fscanf , I used for reading .hex file of the same .raw image.
Input file here is *.raw image
count = 0;
$display("Entered Image read");
while ((data_byte = $fgetc(input_file)) != -1)
$display("%d %h",count,data_byte);
count++;
//if(count == 1440000)
//$finish;
Now the input data shows “ff” after a certain count. the last values are
1439993 ff
1439994 ff
1439995 ff
1439996 ff
1439997 ff
1439998 ff
1439999 ff
Input file changed to *.hex of the same image file
Code changed as follows. file_status = 0 checked. but here it goes beyond the data count (1440000).
count = 0;
file_status = 1;
while (file_status != 0)
file_status = $fscanf(input_file,"%h",data_byte);
count++;
// $finish;
Now i have 2 questions
- How can i correctly read *.raw image completely?
- How can i fetch the EOF in *.hex ?
You will have to show a complete example of what you want to do, not just a piece of it.
The following worked for me and it may help you figure out what you want.
int data,f;
f = $fopen("file","r");
while ((data=$fgetc(f)) !=-1) // raw binary
$display("fgetc:%0d %c",data, data);
$fclose(f);
while ($fscanf(f,"%h",data) !=-1) // hex formatted
$display("fscanf: %h",data);
$fclose(f);
0123 4567
89AB CDEF
Produced the following output
# run -all
# fgetc:48 0
# fgetc:49 1
# fgetc:50 2
# fgetc:51 3
# fgetc:32
# fgetc:52 4
# fgetc:53 5
# fgetc:54 6
# fgetc:55 7
# fgetc:10
# fgetc:56 8
# fgetc:57 9
# fgetc:65 A
# fgetc:66 B
# fgetc:32
# fgetc:67 C
# fgetc:68 D
# fgetc:69 E
# fgetc:70 F
# fgetc:10
# fscanf: 00000123
# fscanf: 00004567
# fscanf: 000089ab
# fscanf: 0000cdef
# quit -f
Once again thanks for your kind reply.
Dave, $fgetc and $fscanf works fine here. But the code is only reading the input file partially.
My input file is ASCII formatted .raw image file. (Not binary or hex). Now your code is reading correctly
in necessary format. but the file pointer is not moving after a certain point. The file seems not corruptive , as i could
read it fully using VHDL file I/O operation.
How can i send the input file as attachment? Any means?
This could be a tool issue, or a coding error. You have never shown enough code to eliminate the latter. If it is a tool issue, you should contact your vendor’s support channel. I cannot help you further on this forum.
Dave,
My requirement is to read from a ASCII formatted input image file and write the data to another ASCII formatted output image file.
I used a 800*600 *.raw(RGB formatted ASCII) file. I used IrfanView tool to generate *.raw(RGB) from *.JPG.
here is my full code. If wanted i can send the input image file as attachment.
I don’t see an option to attach files here in this forum how?
int data;
int count;
integer input_file, file_status,output_file,read_char;
reg [7:0]data_byte;
function new ();
input_file = $fopen("test_800.raw","r");
if(input_file)
endfunction:new
count = 0;
while ((data = $fgetc(input_file)) != -1) // raw binary
$display("fgetc:%0d %h %d",data, data , count);
$fclose(file_status);
/* file_status = $fopen("input_file","r");
while ($fscanf(file_status,"%h",data) != -1) // hex formatted
$fclose(file_status); */
int input_file;
initial
endprogram
Thanks!
The only thing I am left with is a tool issue. Contact your vendor’s support line.
