Illegal Format specifier Error
Can some body tell me what is wrong in this display statement?
module test;
class a;
rand int d[10];
rand int b;
rand int index_max;
constraint c {
foreach (d[i]) d[i] inside {[1:99]};
index_max inside {[1:10]};
b == d.sum(item) with (item.index <= index_max ? item : 0);
a A = new();
$display ("The value of a is %d, index_max is %d, B is %d",A.d,A.index_max,A.b);
Here is the Error :
Error-[IFSF] Illegal format specifier
./chaining.sv, 19
“$display(“The value of a is %d, index_max is %d, B is %d”, A.d, A.index_max, A.b);”
‘d’ is not a valid format specification for argument A.d
Please correct the error and recompile.
In reply to rag123:
Not sure what you are expecting to print, but the variable d is an unpacked array. So you either need to use ‘%0p’ to print it out as an assignment pattern, or select an element of d.
Thanks Dave
