If a certain function parameter is passed by 'ref' how to make following parameters to be non-ref?
In SystemVerilog value can be passed via reference, which is indicated by ref keyword. But if a function has other parameters declared after the ref parameter they also seem to behave like passed-by-reference. Why it is so? (or what rule in LRM applies to that?)
My first thought to this counter-intuitive behavior was ‘it’s simulator bug’, so I checked other tools on edaplayground.com. The results were consistent, so it’s certainly intended behavior. In this case how to undo the ref if I really want to preserve the parameter order I like?
Code listing:
class Test;
  function genArray(int count, ref byte arr[]);
    arr = new[count];
    for(int i=0; i<count; i++)
      arr[i] = $urandom();
  function genArrayWrong(ref byte arr[], int count);
    genArray(count, arr);
module tb;
  Test t;
  byte randomStuff[];
    int myCount = 14;
    t = new;
    t.genArray(14, randomStuff);           // ok
    t.genArrayWrong(randomStuff, myCount); // ok
    //t.genArrayWrong(randomStuff, 14);    // won't compile
    $display("random array: %p", randomStuff);
    $finish;
In reply to mmaciag:
The implicit direction of the first argument is input. The implicit direction of the successive arguments take on the direction of the preceding argument. Directions are: input, output, inout, and ref.
Thanks for quick answer. That’s it! I didn’t know that ref is just another kind of ‘direction’.
The code below compiles fine:
function genArrayWrong(ref byte arr[], input int count);
