my transaction has start bit , data (8 bits) , parity bit and stop bit , am sending transcation @ TX.
what if i want to add RAL to my UVM , how can i do the adapter with this transcation ? i don’t have any write/read enable , adds , can i i specify the 8 bits data , to have write/read operation and some bits for adds and some bits for data? i just want to know if this concept is working or not?
here is reg2bus code @adapter
function uvm_sequence_item reg2bus(const ref uvm_reg_bus_op rw);
seq_item uart_trans;
uart_trans = seq_item::type_id::create(“uart_trans”);
uart_trans.start_bit = 1'b0;
uart_trans.data[0] = (rw.kind == UVM_WRITE) ? 1 : 0;
uart_trans.data[2:1] = rw.addr;
uart_trans.data[7:3] = rw.data;
uart_trans.parity_bit = ^uart_trans.data;
uart_trans.stop_bit = 1'b1;
