Trying to read a hdl path using uvm_hdl_read inside my UVM tetsbecnch. The exixts since I have already confirmed using uvm_check_path. Somebody pleas help
In reply to kevin488:
Do you get an error message or what is your problem in some more detail?
I have given
If(!uvm_hdl_read(“chipset_tb_top.ser.mode_strap”,strap))
‘UVM_error()
It is giving me this error: unable to locate hdl path , either the names is incorrect or you may not have PLI/ACC visibility
Check your tool’s user manual for UVM backdoor accessibility.
I have used the same statement inside build phase to see if it works and it is working but when I use in a function it throws up the uvm error. By the way I’m using simvision
This Mentor/Siemens EDA sponsored public forum is not for discussing tool specific usage or issues. Please read your tool’s user manual or contact your tool vendor directly for support.
