I got warning vlog 2240 saying "Treating stand-alone use of function 'convert2string' as an implicit VOID cast"
I am trying to run my sequence_item class, one of the method(convert2string) in class is not printing as expected can any one help me to solve the issue.
package Definitions;
parameter DATAWIDTH              = 32;
parameter ADDRWIDTH              = 32;
parameter TRANS_WIDTH            = 2;
parameter DATATRANFER_SIZE       = 3;
parameter BURST_TYPE             = 3;
//logic HSEL0, HSEL1, MUX_SEL;                       // Confusion for this line existance
//logic HRESETn, HCLK;                               // Confusion for this line existance
//------------------------------------- Parameters for memory module------------------------
parameter SLAVE_DATAWIDTH = 8;
parameter SLAVE_ADDRWIDTH = 8;
//---------------------------------------Tranfer types' enumeration------------------------------------------
typedef enum
IDLE   = 'b00,
BUSY   = 'b01,
NONSEQ = 'b10,
SEQ    = 'b11
} Trans_t;
//--------------------------------------- Burst operation types enumeration----------------------------------
typedef enum
SINGLE = 'b000,
INCR   = 'b001,
WRAP4  = 'b010,
INCR4  = 'b011,
WRAP8  = 'b100,
INCR8  = 'b101,
WRAP16 = 'b110,
INCR16 = 'b111
} BType_t;
//--------------------------------------- Burst Size (Bits) Enumeration---------------------------------------------
//---------------------------------------STRUCTURE for Address and Data--------------------------------------
//---------------------------------------Signal for Slave----------------------------------------------------
typedef enum
OKAY  = 'b0,
ERROR = 'b1
} Response_t;
endpackage
import Definitions::*;
import uvm_pkg::*;
`include "uvm_macros.svh"
class transaction_a extends uvm_sequence_item;
	rand logic [ADDRWIDTH-1:0] HADDR []; //this dynamic array is to store
	rand logic [DATAWIDTH-1:0] HWDATA [];
	rand bit HWRITE, HMASTLOCK, HREADY; //*
	rand BType_t HBURST; //*
	rand Trans_t HTRANS [];
	logic [3:0] HPROT; //*
	rand bit [2:0] HSIZE; //*
	rand bit POSITION_BUSY []; //array to store position of busy
	rand int NO_OF_BUSY_STATES; //Number of busy states in a transafer*
	//Output data to DUT
	logic [DATAWIDTH-1:0] HRDATA;
	Response_t HRESP;
	constraint  size_of_ADDRandDATA	{
						solve HADDR before HWDATA;
						HADDR.size == HWDATA.size;
	constraint 	addnoteqz 	{
						HADDR.size > 0;
	constraint	addrsize	{
						solve HBURST before HADDR;
						if(HBURST == SINGLE)
							HADDR.size == 1;
						else if(HBURST inside {INCR4, WRAP4})
							HADDR.size == 4;
						else if(HBURST inside {INCR8, WRAP8})
							HADDR.size == 8;
						else if(HBURST inside {INCR16, WRAP16})
							HADDR.size == 16;
							HADDR.size == 5;
	constraint	addr_allignemnet	{
							if(HSIZE == 1)
							foreach(HADDR[i])
								HADDR[i][0] == '0;
							else if(HSIZE == 2)
							foreach(HADDR[i])
								HADDR[i][1:0] == '0;
	constraint	addr_incr	{
						if(HBURST inside {INCR, INCR4, INCR8, INCR16})
						foreach(HADDR[i])
							if(i!=0)
								HADDR[i] == HADDR[i-1] + (2**HSIZE);
	constraint	single_op	{
						if(HBURST inside {SINGLE})
							HTRANS.size == 1;
							HTRANS[0] inside {IDLE, NONSEQ};
	constraint	incr4816_wrap	{
						if(HBURST inside {INCR4, WRAP4, INCR8, WRAP8, INCR16, WRAP16})
							HTRANS.size == HADDR.size;
							foreach(HTRANS[i])
							if(i!=0)
								HTRANS[i] == SEQ;
								HTRANS[i] ==NONSEQ;
	constraint	oincr	{
					if(HBURST inside {INCR})
						foreach(HTRANS[i])
						if(i == 0)
							HTRANS[i] == NONSEQ;
							HTRANS[i] inside {NONSEQ, SEQ};
	constraint	addrincr	{
						if(HBURST == INCR)
						foreach(HTRANS[i])
							if(i!=0)
								if(HTRANS[i-1] == NONSEQ && HTRANS[i] == SEQ)
								else if(HTRANS[i-1] == NONSEQ && HTRANS[i] == NONSEQ)
									HADDR[i] != HADDR[i-1] + (2**HSIZE);
								else if(HTRANS[i-1] == SEQ && HTRANS[i] == SEQ)
	//////////////////////////////////////////////CONSTRAINTS/////////////////////////////////////////////////////////////////
	`uvm_object_utils_begin(transaction_a)
		`uvm_field_int(HWRITE, UVM_DEFAULT)
		`uvm_field_int(HMASTLOCK, UVM_DEFAULT)
		`uvm_field_int(HREADY, UVM_DEFAULT)
		`uvm_field_int(HPROT, UVM_DEFAULT)
		`uvm_field_int(HSIZE, UVM_DEFAULT)
		`uvm_field_int(NO_OF_BUSY_STATES, UVM_DEFAULT)
		`uvm_field_enum(BType_t, HBURST, UVM_DEFAULT)
		`uvm_field_array_int(HADDR, UVM_DEFAULT)
		`uvm_field_array_int(HWDATA, UVM_DEFAULT)
		`uvm_field_array_int(POSITION_BUSY, UVM_DEFAULT)
		`uvm_field_array_enum(Trans_t, HTRANS, UVM_DEFAULT)
	`uvm_object_utils_end
    	virtual function string convert2string();
		return $sformatf("[%0s] at time %t HADDR == %d, HWDATA == %d, HWRITE = %d, HMASTLOCK = %d, HREADY = %d, HBURST = %d, HTRANS = %d, HPROT = %d, HSIZE = %d, HRDATA= %d, HRESP =%d\n", get_type_name(), $time, this.HADDR, this.HWDATA, this.HWRITE, this.HMASTLOCK, this.HREADY, this.HBURST, this.HTRANS, this.HPROT, this.HSIZE, this.HRDATA, this.HRESP);
	function new(string name = "transaction_a");
		super.new(name);
	transaction_a trans[5], trans2, trans3,  trans4;
	initial
		foreach(trans[i])
			trans[i] = transaction_a::type_id::create("trans[i]");
			assert(trans[i].randomize);
			//trans[i].convert2string();
		trans[1].print();
		trans[1].convert2string();
output :
vlog -source -lint -sv sequence_item.sv -L C:/questasim64_2022.3/uvm-1.2/
QuestaSim-64 vlog 2022.3 Compiler 2022.07 Jul 18 2022
Start time: 13:30:08 on Jul 20,2023
vlog -reportprogress 300 -source -lint -sv sequence_item.sv -L C:/questasim64_2022.3/uvm-1.2/
– Compiling package Definitions
** Note: (vlog-2286) sequence_item.sv(63): Using implicit +incdir+C:/questasim64_2022.3/uvm-1.2/../verilog_src/uvm-1.2/src from import uvm_pkg
– Compiling package sequence_item_sv_unit
– Importing package Definitions
– Importing package C:/questasim64_2022.3/uvm-1.2.uvm_pkg (uvm-1.2 Built-in)
– Compiling module top
sequence_item.sv(197): trans[1].convert2string();
** Warning: sequence_item.sv(197): (vlog-2240) Treating stand-alone use of function ‘convert2string’ as an implicit VOID cast.
Top level modules:
top
End time: 13:30:09 on Jul 20,2023, Elapsed time: 0:00:01
Errors: 0, Warnings: 1
In reply to marathuteja:
The function convert2string() returns a string value. You get this warning when you call a function and ignore the return value. You probably want to call print() instead.
