I am getting FATAL ERROR like "my_seq_path already started "
Hello,
While running the test, I am getting following FATAL Error.
UVM_FATAL @ 65623054000: uvm_test_top.some_path.axi_mst_agent.sqr@@rd_seq [SEQ_NOT_DONE] Sequence uvm_test_top.m_loner_env.hps_cpu_inst.axi_mst_agent.sqr.rd_seq already started
Do anyone face this issue? Please help how to get ride of it.
Thanks in advance.
Anu
In reply to anu.anu:
While looking into the UVM Source code i find this :
if (!(m_sequence_state inside {UVM_CREATED,UVM_STOPPED,UVM_FINISHED})) begin
uvm_report_fatal(“SEQ_NOT_DONE”,
{"Sequence “, get_full_name(), " already started”},UVM_NONE);
But not understating, So i suppose to kill that sequence?
Thanks
Anu
You have started your sequence rd_seq twice at the same time on the same sequencer.
Hello chr_sue,
Might be. i am not sure. Actually it is SOC Level Env.
But is there any way , so that i can know who all started the sequences. I mean which all components are calling the sequences ??
Thanks
Anu
You can see this in your code. Sequences are always started on sequencers.
From the error message, it shows the rd_seq is issued on sequencer of axi_mst_agent as below. But you may need to look at your test code where the rd_seq is started.
