I’m looking at the “uvm hello world” example at UVM Hello World - EDA Playground ,
and I’m wondering why do we need line 15 “import my_testbench_pkg::*;”?
This is a basic UVM "Hello World" testbench.
Explanation of this testbench on YouTube:
https://www.youtube.com/watch?v=Qn6SvG-Kya0
`include "uvm_macros.svh"
`include "my_testbench_pkg.svh"
// The top module that contains the DUT and interface.
// This module starts the test.
import uvm_pkg::*;
// Instantiate the interface
dut_if dut_if1();
// Instantiate the DUT and connect it to the interface
dut dut1(.dif(dut_if1));
// Clock generator
dut_if1.clock = 0;
forever #5 dut_if1.clock = ~dut_if1.clock;
// Place the interface into the UVM configuration database
uvm_config_db#(virtual dut_if)::set(null, "*", "dut_vif", dut_if1);
// Start the test
run_test("my_test");
// Dump waves
$dumpfile("dump.vcd");
$dumpvars(0, top);
I understand that the compiler looks inside the imported pkg only if it doesn’t find the wanted name in the local scope.
so I understand that we need to import “uvm_pkg::*” in order to use “run_test()”,
but nothing in “testbench.sv” is using any class within “my_testbench_pkg.svh”,
so why do we need to import it?
what is the actual flow in uvm that makes it knows “my_test” class?
I understand it’s related to a factory and the line “`uvm_component_utils(my_test)”,
but why isn’t compilation enough?
why do I have to use “import my_testbench_pkg::*;”?
why the test fails when I delete this import?
(UVM_FATAL @ 0: reporter [INVTST] Requested test from call to run_test(my_test) not found.)
so i’m including it, it compiles…
why should I also import it in “testbench.sv” if no one is using it there?
I imagine that it needs to be imported inside the uvm_pkg, inside run_test(), maybe even in the factory, where uvm instantiate “my_test” class. but obviously we can’t inject an import into the uvm files. so what is the mechanism?
Of course you can include this file. In your simple environment it does not make any difference.
Packaging files belonging together like agent data in a package allows you to import these data in any place you need it like a different project.
I don’t understand how your answer relates to my questions…?
the pkg is already included:
`include “my_testbench_pkg.svh”
isn’t this enough? why should I also import it inside the testbench module if no one is using it there?
(I have a thought maybe it relates to some compiler optimization? maybe without the import the compiler thinks no one is using those classes so he through them away…?)
Yes, that is correct, the compiler needs to know that someone is using the package.
Many compilation scripts compile much more than is needed for a particular simulation. Some tools require the user specify a top-level module, and the elaboration process figures out just the relevant units needed from that point downwards.
The UVM factory relies on initializing a static member of specialized parameterized class at time 0. That initialization calls a function that “registers” the class by adding an element to an array inside the UVM package. (See this article for more about that)
But that initialization code only gets executed if it’s determined that the package is needed for the simulation. There are a number of ways that can happen, which may involve tool specific options:
That package gets imported directly or indirectly into the design
You tell the compiler the package is a top-level unit.
You tell the compiler you want everything compiled to be part of the design.
