In reply to srbeeram:
You can create a counter that gets incremented in post_randomize
class exa;
rand bit [31:0] addr;
bit [2:0] counter;
constraint con1 { counter == 0 -> addr inside {['h0:'h100]};}
constraint con2 { counter == 0 -> ! (addr inside {['h20:'hE0]} ) ;} // ! has higher precedence than inside
constraint con3 { addr[1:0]==0 ;}
constraint con4 { counter != 0 -> addr == const'(addr+4) ; }
if (counter++==4) counter =0;
You will have to adjust the range constraints so that the series does not overlap. If 'h100 is a valid starting address, is 'h104 also valid?
