specification:
how to write a assertion for check clk frequency?
sys_clk 50-300MHZ
flash_clk 200MHZ
flash_clk1 300-400MHz
in form of MAX:MIN:NOMINAL
In reply to anjali swarnkar:
See Clock Frequency Checker | Verification Academy
- SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
- VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy
- http://systemverilog.us/vf/SolvingComplexUsersAssertions.pdf
- “Using SVA for scoreboarding and TB designs”
http://systemverilog.us/papers/sva4scoreboarding.pdf - “Assertions Instead of FSMs/logic for Scoreboarding and Verification”
October 2013 | Volume 9, Issue 3 | Verification Academy - SVA in a UVM Class-based Environment
BTW, use realtime instead of time Anyway, back to your question.
property p_clk_hi;
realtime v;
@(posedge clk) (1, v=$time) |-> @(negedge clk) ($realtime-v)==300ns;
ap_clk_hi: assert property(p_clk_hi);
// Above measures the time btween a posedse of clk and any negedge thereafter.
// For a normal clock, if you expect a duty cycle of 300HI and 700lo,
// that and chcecks the hi time. If there is a gligtch, the assertion will fail as
// the time will not be 300ns.
property p_clk_lo;
readtime v;
@(negedge clk) (1, v=$time) |-> @(posedge clk) ($realtime-v)==700ns;
ap_clk_lo: assert property(p_clk_lo);
// same thing here for the time the clock is lo.
