How to work on system C structs enums and lists to convert code into system verilog
I have a working SystemC code as shown below which I am trying to convert into Systemverilog to learn it. although original code was very large but I shortened it down to narrow issues
typedef int token_type;
struct packet
	int src_x, src_y;
	int dest_x, dest_y;
	token_type token;
	packet(int sx = -1, int sy = -1, int dx = -1, int dy = -1,
		token_type t = token_type())
		: src_x(sx), src_y(sy), dest_x(dx), dest_y(dy), token(t)
	bool operator==(const packet &x) const
		return (x.src_x == src_x) && (x.src_y == src_y)
			&& (x.dest_x == dest_x) && (x.dest_y == dest_y)
			&& (x.token == token);
}; // struct packet
std::ostream &operator<<(std::ostream &o, const packet &p);
void sc_trace(sc_trace_file *tf, const packet &p, const std::string &name);
SC_MODULE(router)
	sc_in<bool> clock; // port for the global clock
	enum { PE = 0, PORTS };
	sc_in<packet> port_in[PORTS]; // input ports
	sc_out<packet> port_out[PORTS]; // output ports
	void main();
	SC_CTOR(router)
		: x_(-1), y_(-1)
		SC_METHOD(main);
		sensitive << clock.pos();
	void set_xy(int x, int y);
protected:
	std::list<packet> out_queue_[PORTS]; // output queues
	int x_, y_; // location of the router
}; // router
I am calling above functions as shown below
	char buf[100];
	return o << buf << ", " << p.token;
void router::main()
	assert((x_ != -1) && (y_ != -1));
void router::set_xy(int x, int y)
	assert((x_ == -1) && (y_ == -1));
	assert((x != -1) && (y != -1));
	x_ = x;
	y_ = y;
and my main program runs all of above with below code
SC_MODULE(top)
public:
	enum { N = 1 }; //enum { N = 2 };
	router *routers[N];
	sc_signal<packet> router_to_pe[N], pe_to_router[N];
	sc_signal<bool> clock;
	SC_CTOR(top)
		create_network();
protected:
	void create_network()
		for (int i = 0; i < N; ++i)
			char name[100];
			sprintf(name, "router%d", i);
			// create router
			routers[i] = new router(name);
			routers[i]->set_xy(i, 0);
			routers[i]->clock(clock);
			routers[i]->port_out[router::PE](router_to_pe[i]);
			routers[i]->port_in[router::PE](pe_to_router[i]);
}; // top
int sc_main(int argc, char *argv[])
	srand(0);
	top top_module("top");
	printf("cycle  0 ================================\n");
	sc_start(0, SC_NS);
	for (int i = 1; i < 20; i++) {
		printf("cycle %2d ================================\n", i);
		top_module.clock.write(1);
		sc_start(10, SC_NS);
		top_module.clock.write(0);
	cin.get();
	return 0;
Systemverilog code I have written to date is shown below and errors I see are shown on lines which occur on compilation
class pkt;
	int src_x, src_y;
	int dest_x, dest_y;
	token_type token;
	function new(int sx = -1, int sy = -1, int dx = -1, int dy = -1,
		token_type t);
		this.src_x=sx; this.src_y=sy;
		this.dest_x=dx; this.dest_y=dy;
		this.token=t;
	function logic operator(pkt x);
pkt packet;
//parameter PE = 4'b0000,
//PORTS = 4'b0101;
module router(clock,port_in,port_out);
	input clock;
	enum { PE = 0, PORTS } ports;
	packet out_queue_[$:PORTS];//error here is syntax: error unexpected '$'
	input [0:packet]  port_in[0:PORTS];//error here is illegal reference to class "packet"
	output [0:packet] port_out[0:PORTS];
	int x_, y_;
	always @(posedge clock)
I wanted to know how to implement list of type packet and arrays of sc_in and sc_out of type packet in Systemverilog, or my total approach needs to change?
