HI,
I’m trying to use $sformatf(“0x%X”, my_number)
my_number is 8 bits number and i want sformatf to print this number is 2-digits width field and no leading “0”.
how can i make it ?
Thanks !
HI,
how can i make it ?
Thanks !
In reply to snognogt:
HI,
how can i make it ?
Thanks !
Can you provide an example of what you want to display?
What you have is that if my_number = 8’h24. Your sformatf will return a string that is “0x24”.
You have to Modify your formatter like this
$sformatf("0x%0h", my_number)
%0h prints only the numbers really needed.
In reply to DVCoder:
Hi
For example - if my_number is 0x24 it prints ox24 (which is ok) but if my number is 0x8 - i want it to print 0x8 but keep the field width as 2 digits (which means that for example :
sprinft(“0x%X this is my number”, my_number)
i want to get for the 2 case :
0x24 this is my number
0x8(space) this is my number
as you can see i want to make the case in the second line that it will print 0x8 in 2 digits field width.
same question goes for the %d case…
You cannot suppress leading 0’s in the minimum field width needed to display in a radix other than decimal. What you are asking for is left justification with zero suppression. Some tools will let you do “%-2d”. But for other radixes, you need to strip the leading 0’s manually and add a trailing space for each that you find.
